Ok, I'm fixing a pc for a friend. When I turned on the computer I was blocked out by some dumb message about copyrights and wanting to pay $200. Finally was able remove some of the files, delete from start up, etc. installed spy bot search and destroy, ran the scan and removed all entries. Used the pc on and off for a few days. No issues. Gave the pc back... Within 2 days...it's back. Is there a better freeware scanner/remover for this. I'm at my wits end with this.
https://www.neowin.net/forum/topic/1120426-need-help-removing-virusmalware/
1. Boot in safemode
2. Empty ALL temp folders, including user temp folders, not just windows
3. Reset IE, checking the box to delete everything
4. Open regedit:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run
and
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
Delete any suspicious looking entries
Also delete anything in HKEY_CURRENT_USER\Software and HKEY_LOCAL_MACHINE\SOFTWARE that look malware related
Open MSCONFIG and disable anything that looks suspicious in there too
Reboot in normal mode, and run a full scan with a fully updated malwarebytes
You have already scanned with spybot but do it again anyway
Another good thing is installing Avast Free, and do a "Boot Time Scan" this will be able to remove malware that can not be killed inside of windows
Download and run a scan with "Hijack This" remove any suspicious entries in there too
Scan a couple of times with all the above programs until they all return a clean result
If you still have a problem after all that, wipe > reinstall windows
  • Like 3
  On 18/11/2012 at 16:34, jerzdawg said:
What exactly would be considered suspicious? I'd assume they would label anything that would set off red flags..
Well just anything you don't recognise as being installed on the machine as a genuine app, a lot of malware will have registry keys with weird symbols, such as !"?$%^&*&()_) or the name of the fake AV that pops up
Normally pretty easy to spot, the first 2 keys I mentioned are what windows calls to startup with windows, so if you don't want anything starting up with windows, delete those keys, and in MSCONFIG
  On 18/11/2012 at 17:27, sc302 said:
where you live? I am in warren county. I could get it fixed up for you. also don't use that old pos hijackthis...use olt
http://www.geekstogo...ldtimer-listit/
What is wrong with HijackThis ? Its a great piece of software
Latest version is 2.04....It doesn't work properly with 64bit oses. It also doesn't dig as deep as otl.
Compare a hjt log with a otl log.
sample otl log
http://www.bleepingc...opic313328.html
sample hjt log
http://www.techsuppo...down-14837.html
which do you think is more thorough and can help you better find the cause?
Ok, never used OTL, still HijackThis is a decent app, using both would be better than not using HJT, never had a problem with HJT and 64bit OSs though
read about hjt and 64 bit, while this isn't necessarily a problem people unfamiliar with it will go to disable critical processes and screw their computers up more. I don't recommend running this as a novice, nor do I recommend running it over the internet being that people can be tempted to try to fix it themselves causing more issues. bottom line, it doesn't work well with 64 bit oses and otl produces the similar findings as hjt with many more pieces to the os puzzle (more files, more reg entries, more points of infection, etc). Running otl with a good rootkit detection software, like gmer, will allow you, the tech, to actually find something useful and be able to repair the computer.
http://www.experts-e...it-Systems.html
That being said, it may take a few hours to go through and verify a otl report.
Well that doesn't render HJT useless on 64bit systems, we're not looking for missing file entries, we're looking for malware entries, make no difference if HJT can't find 64bit files
And more to the point, I don't know many 64bit versions of malware
not exactly useful either. if it is not useful, it is useless IMO.
you could do what others said and waste your time, or do what will be the easiest. Download a 10 meg file mawarebytes.com from here (filehippo link) on to a usb key. Boot into safe mode, install, run a scan, let it remove it. Done. If you want to do it the hard way, follow the other posts above.
Secret....malware bytes doesn't remove everything. Their root kit detection piece is still in beta last time I checked. Malware bytes is not the end all be all.
I have been around a lot of malware, and I can tell you with 100% certainty that malware bytes doesn't remove all of it. Just a good portion. I run a min of three different removal utilities mwb being one of them when cleaning computers. Mwb isnt the first thing i run, it is the last. I do know its limitations.
I have been around a lot of malware, and I can tell you with 100% certainty that malware bytes doesn't remove all of it. Just a good portion. I run a min of three different removal utilities mwb being one of them when cleaning computers. I do know its limitations.
after servicing a couple thousand machines over the last couple years , i have had a 100% success ratio with malwarebytes when scanning in safe mode. Could you give me an example of malware that it can't remove? I would like to download it and see for myself.
note: i LOVE getting new stuff to test virus removal techniques. being serious.
Pick any root kit. The Remote Desktop attack 6months ago it couldn't detect (MSE was the first that did). Had problems finding, file name was close to a windows file name and I kept overlooking it.
I have been doing manual virus removal since late 90s. I have thousands over you. Hell, the hospital I was working at had a whole site infection over 10000 computers and hundreds of servers. Nightmare.
could you give me even just 1 name of a rootkit that you could not remove with it? the worst one in your mind/experiance
This. Why make the removal process difficult?
Is it that hard to google root kit names, like I said pick one any one. Pull any one out of a google search. Malware bytes is 100% ineffective against any root kit. It doesn't have the scan engine for it, therefore it can't detect or repair against this type of infection. Google redirect is one.
Here you go read through and you will see that the user running malware bytes has no effect against it. http://www.bleepingcomputer.com/forums/topic434638.html
  On 18/11/2012 at 18:46, Detection said:
Huh? How is it not useful ?
What do you have against HJT ? It works, what more do you want ?
I don't like doing things twice and skimming through information I have been through before.
  On 18/11/2012 at 18:53, sc302 said:
Is it that hard to google root kit names, like I said pick one any one. Pull any one out of a google search. Malware bytes is 100% ineffective against any root kit. It doesn't have the scan engine for it, therefore it can't detect or repair against this type of infection. Google redirect is one. Here you go read through and you will see that the user running malware bytes has no effect against it. http://www.bleepingcomputer.com/forums/topic434638.html I don't like doing things twice and skimming through information I have been through before.
Ok, well each to their own, lets not hijackthis thread with our differences ;)
Is it that hard to google root kit names, like I said pick one any one. Pull any one out of a google search. Google redirect is one.
Surprised you could not give one from your own extensive experiences and instead saying Google one. I am having no luck finding an .exe for the google redirect to infect myself with. Google is full of solution links and no actual download links (of course and expected). Do you know where i can get the .exe file? Or maybe a website that does give the infection?
    • So is Ubuntu and Fedora (with GNOME). It's a welcome move and those that need X11 can easily install as pointed out in the article it but that won't stop a loud minority from whining of course. Funny but It will actually be easier to install X11 on Ubuntu then enable Flatpak support/Flathub and use them.
    • End of an era? Kubuntu is removing default support for X11 in new installs by David Uzondu X11, the old window system whose days have long felt numbered, just saw another one of its major supporters head for the exit. Kubuntu has decided to follow its parent distro's lead, making its next release, version 25.10, a Wayland-only affair for fresh installs. It seems many Linux developers see Wayland as the future. Just recently, Linux Mint started working to improve support for the protocol in Cinnamon, tackling lingering issues with keyboard layouts and input methods. You can even see the progress in KDE's development, where an upgrade to Wayland PiP is planned for KDE Plasma 6.5. So what's the logic behind dropping a session that, for the most part, still works? According to Kubuntu's Rik Mills, the team wants to "rip off this sticking plaster" now, in an interim release, rather than ###### off a lot of people by doing it in the next Long-Term Support version, 26.04. The developers feel that maintaining code for the aging X11 system holds back progress on security and new features that Wayland can enable more easily. Plus, supporting two separate display servers is a massive undertaking. Of course, this change might have some people worried, but relax; all is not lost if you still need the old session. If you're running hardware that acts up, like some older NVIDIA cards, or who relies on an ancient application that doesn't play nicely with the XWayland compatibility layer, you can still get your familiar session back. Just enter the following command in your terminal: sudo apt install plasma-session-x11 Once that command finishes, the X11 session will appear as an option on the login screen, so you can carry on as before. As OMGUbuntu notes, not everyone in the Ubuntu family is following its lead just yet. Other official flavors like Xubuntu, Ubuntu Budgie, and Ubuntu Cinnamon are expected to keep offering an X11 session on their default installs for this cycle.
    • Mangohud hasn't been built into "Steam Deck", it has been built into SteamOS. I understand that your goal is to try and praise MS for a simple feature that everyone else has, but we are comparing OS vs OS. Hardware does not have anything "built-in". Software does. Like it or not, SteamOS has it "built-in". And it is far superior to XBOX game bar's information.
    • Please don't inject yourself into a discussion you did not read or understand what was said. No where did I say Windows was hard to use. I knew when seen two notifications with your handle the replies they were going to be a waste of time to read.
    • Exactly. The UI feels a lot snappier when animations are disabled. I think I might actually give it a try for a while, I'm liking it so far.
      viraltui earned a badge
      serfegyed earned a badge
      firey earned a badge
      fettermanj earned a badge
      142
