When Setting Up Dual Monitors with Nvidia The Second Display got Low Resolu
I have just setup a dual monitor system with a 23 inch LED monitor and a 19 inch LCD monitor. The 23 inch one is connected through HDMI. The 19 inch one is connected to the analogue port of the same GPU (Nvidia Geforce 210).
In Ubuntu 12.10, after installing Nvidia drivers, the 23 inch monitor works fine but the 19 inch monitor got a very low resolution. When I set the correct resolution, the desktop goes out of the screen. Also I feel a small lag in animations on the 23 inch monitor. Things work fine under Windows 8.... My questions are...
  1. How to fix the resolution in the small monitor?
  2. What is causing the lag and how to fix it?
Are you using the default DE, Unity? There's something, oh, I cant remember... Let me check for you, unless someone beats me to it.. :p
Yep :) Im using Unity! Please help :D
Unity seem to have horrible dual screen support. From my experiences, it's actually regressed since Unity was made default and Gnome 2 abandoned.
I even tried Linux Mint 14 which have cinnamon instead... In Mint also I face the same issue :(
Here's my xorg.conf :
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 310.14 (buildd@komainu) Tue Oct 23 23:48:50 UTC 2012
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
# HorizSync source: edid, VertRefresh source: edid
Identifier "Monitor0"
VendorName "Unknown"
ModelName "CRT-1"
HorizSync 30.0 - 81.0
VertRefresh 50.0 - 75.0
Option "DPMS"
EndSection
Section "Monitor"
Identifier "Monitor1"
ModelName "Samsung S23B370"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "GeForce 210"
EndSection
Section "Device"
Identifier "Device1"
Driver "nvidia"
BusID "PCI:1:0:0"
Screen 1
EndSection
Section "Screen"
# Removed Option "metamodes" "DFP: nvidia-auto-select +0+0, CRT: 1360x768 +1920+0"
# Removed Option "metamodes" "DFP: nvidia-auto-select +0+0, CRT: 1360x768_60 +1920+0"
# Removed Option "metamodes" "CRT: 1360x768_60 +0+0"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-1"
Option "metamodes" "CRT: nvidia-auto-select +1920+0, DFP: nvidia-auto-select +0+0"
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen1"
Device "Device1"
Monitor "Monitor1"
DefaultDepth 24
Option "Stereo" "0"
Option "metamodes" "DFP: nvidia-auto-select +0+0"
Depth 24
EndSubSection
EndSection
[/CODE]
Just found the issue... Its not a software problem... Its the cable! If some one have this same issue... If the second display is not detected or its detected as a CRT... Change the VGA cable and check. It fixed my issue :)
Thanks for everyone who posted here :D
