Best thought process for converting a WinCE Program to Android?
We have an old inventory program on a WinCE 6.1 device that connects back to a AS/400 mainframe. It was designed in VB using Visual Studio 2008. We are beginning the thought process of updating the program to work on a new android inventory scanner running ICS.
Any idea what would be the best and most efficient way of doing the conversion? Is a complete re-write needed or can we use an IDE like netbeans to do a conversion?
2 answers to this question
More than likely you will need to do a complete re-write of the application. If you design it well, the code in Java for Android should be shorter and more maintainable than the equivalent in VB for WinCE. If there is one thing Java excels at IMHO, its ease of use.
Edit: I found a good article by a developer who ported a large WinCE application to Android. While some of the things the author describes may help you, his application was written primarily in C++, not VB.
Edit 2: After extensive searching, I found several solution purporting to convert VB/C# to Java (not the Android variant, but close), but they all seemed to be expensive, incomplete, poor quality, or all of the above. Using an automatic converter seems like an excellent way to produce buggy and unmaintainable code.
    • Clearly a lot of gamers. And I'm sorry but you are wrong, my 7800x3d (single ccd) offers huge benefits to me as a AAA 1440p gamer. And it's pretty dumb to crap on 1080p gamers as they make up like 90+% of steam gamers. But no, the x3d does not just offer benefits to esport gamers (one of the stupidest things I've seen in a while AND THATS SAYING SOMETHING.) Abd when I built my rig with my 7800x3d, I paired it with a RX7900xt and couldn't be happier.
    • Um, someone needs to tell this author the 7800x3d is a single ccd and shouldn't be affected. If this only effects the dual ccd, 7800x3d owners need not worry
    • Popular File Explorer alternative Files gets signature check, improved dual-pane, and more by Taras Buria A new update has arrived for File Preview, a feature-packed file manager for Windows 10 and 11. Version 3.9.14 introduces a useful new feature for file properties, dual-pane improvements, the ability to resize columns in the Columns View, and more. Starting with the Properties dialog, it now features a "Signatures" tab where you can view digital signatures associated with the file and their properties, such as version, issuer, expiry date, and more. You can also click the "Details" button to open Windows' native dialog. The dual-pane feature has been tweaked for a more intuitive experience. The "Add pane" command is now "Split pane." There is a new quick action for toggling dual-pane mode on or off, and settings now have a dedicated section for dual-pane mode. Finally, columns in the Columns View are now resizable, and search results now have a header with your current query. In addition to releasing the update, developers said the following regarding performance complaints from users: Files Preview is available in the Microsoft Store. You can purchase it there to support developers. Alternatively, you can get the app for free from the official website, and if you want to help developers with contributions or ideas, check out their Discord and GitHub.
    • So the iPhone only has a leading position in a few markets around the world: US, UK, UAE, couple of other smaller ones. As a result of the far more mixed eco-system Whatsapp is a lot more popular outside of the US than I think a lot of American's may realise. It's pretty much the messaging standard in the UK
      Soeaker4thedead earned a badge
      kryptickid earned a badge
      Nemesis-IV earned a badge
      Aidan Helfrich earned a badge
    • Collaborator
      bullgod69 earned a badge
      Collaborator
      151
      117
      wakjak
      113
