So. ive installed a 3rd party theme.. but for some reason It doesent look as it suppose to.. (I patched files using Universal Theme Patcher)
As shown on picture.. Red rectangled zones are suppose to have background picture..
  • 4 weeks later...
  On 18/07/2013 at 07:22, illage3 said:
Its likley a problem with the theme its self rather than the patcher.
well.. the site I get has lot of skins and non of them are working as they suppose to..
Here is like some sort of an tutorial of how to make his/her site skins work.. but I dont really understand it and even managed to break my PC once (had to restore files with CMD) - http://theme-windows.blogspot.com/2013/03/background-folder-explorerframe.html
So if you have any slightest idea of what is being explained on site (or get an another idea of what the problem might be) Then please explain in steps.
  • 3 weeks later...
  • 3 weeks later...
Did you get any dll files with the theme?
  • 4 weeks later...
  On 01/09/2013 at 13:01, Jamushroom said:
I there a "Shell" folder inside the theme folder? Because from the looks of it, those parts are being skinned by the files in that folder.
C:\Windows\Resources\Themes\Shingeki No Kyojin By Bazzh\Shell\NormalColor\shellstyle.dll this one?
If you are on Windows 8, make sure to check if the themes are made for Windows 8.. otherwise some (or all) of the themes that are made for old versions of Windows won't work on Windows 8..  Contact the theme creator about the problem you have.
I have had problems with the themes before... So I had to choose other themes that worked on the current Windows.
Im on windows 7
