By Copernic · Posted
By zikalify · Posted
By PsYcHoKiLLa · Posted
By Chay Meredith · Posted
We rely on ads to keep creating quality content for you to enjoy for free.
Please support our site by disabling your ad blocker.
Continue without supporting us
+Red King Subscriber²
EDIT 2:
Latest problems and questions are most likely on the last page. This thread is now used for C++ / C# questions I have (so not to create a thread per question).
I have a C# (GUI) project which in the most dumb way possible generates a fractal and well, I thought it would be fun to code the performance critical section C++ - a language that I don't know
So I added a C++ CLR Library Project - blank and managed to set it 64-bit after a few failed attempts.
I referenced the C++ project from the C# portion.
Issue is I cannot step into it. I pause where I call the C++ class and tell it to Step Into and it doesn't.
What am I doing wrong here?
EDIT,
Some other questions,
C# byte is just an unsigned char in C++? (I am going to be dealing w/ BGR values)
If I want to run a function in a thread in C++, is it true that I need to pass a struct pointer containing all the values?
Edited by _AlexanderLink to comment
https://www.neowin.net/forum/topic/1169195-step-into-referenced-c-project-from-c-project/Share on other sites
13 answers to this question
