Help with The Speed of Sound C++ Program
So I am suppose to write a program that displays a menu for allowing the user to select air, water or steel. After the user has made a selection, s(he) should be asked to enter the distance a sound wave will travel in the selected medium, then whether this distance is in feet or miles. The program will then display the amount of time it will take for sound to travel this distance (in seconds).
Medium / Speed
Air = 1,100 feet per second
Water = 4,900 feet per second
Steel = 16,400 feet per second
So this is what I got so far:
#include <iostream>
#include <iomanip>
using namespace std;
int main()
    int choice;
    int distance;
    double amountOfTime;
    const double Air = 1100;  //feet per second
    const double Water = 4900; //feet per second
    const double Steel = 16400; //feet per second
    cout << "\t\tThe Speed of Sound \n";
    cout << "Please select your medium \n\n";
    cout << "1. Air \n";
    cout << "2. Water \n";
    cout << "3. Steel \n";
    cout << "Enter your choice: ";
    cin >> choice;
    cout << "Enter the distance the sound wave will travel: ";
    cin >> distance;
    cout << setprecision (4) << fixed;
    cout <<
    if (distance == 0)
       cout << "Distance must be greater than zero\n";
    else if (choice >= 1 && choice <=3)
       switch (choice)
          case 1: amountOfTime = distance / Air;
               break;
          case 2: amountOfTime = distance / Water;
               break;
          case 3: amountOfTime = distance / Steel;
       cout << "The amount of time it will take to travel is ";
       cout << amountOfTime;
       cout << " seconds" << endl;
    return 0;
The program works but I still need help in writing the code to ask the user on whether if they want the distance in feet or miles within my program and with a conversion in the code that will display the result of the feet or miles that they will want inputted because so far the distance I ask the user only displays the standard of feet, thanks!
4 answers to this question
You seem to know how to let the user enter things, so entering whether they want the distance in feet or miles should be no problem. The conversion is just a multiplication by the correct factor. What exactly is unclear to you? Please be more specific than "I need help".
well I got the asking the user down but right after "cout << setprecision (4) << fixed;", should I go onto the next line and ask "cout << "Do you want the distance in feet or miles: ";" and what should I do after that when I create that question? sorry I am kind of new, this is my two months of C++
#include <iostream>
#include <iomanip>
int main()
    int choice;
    int distance;
    cin >> choice;
    cin >> distance;
    if (distance == 0)
       switch (choice)
               break;
               break;
    return 0;
So I put the question in asking the user if they want the distance in feet or miles but where would I put the conversion of feet to miles in the program to make the program work?
Your units are in feet by default, so if the user enters feet, you do nothing special. If the user enters meters, you convert all your quantities to meters before your switch(choice) structure.
The conversion might look like this:
double metersPerFeet = 0.3something;
Air *= metersPerFeet;
Water *= metersPerFeet;
Now is the distance entered by the user in feet or meters? I guess you should ask about the units of measure before the distance, so it's clear what unit the user is expecting.
    • Shotcut 25.07 by Razvan Serea Shotcut is a free, open source, cross-platform video editor for Windows, Mac and Linux. Major features include support for a wide range of formats; no import required meaning native timeline editing; Blackmagic Design support for input and preview monitoring; and resolution support to 4k. Editing Features Trimming on source clip player or timeline with ripple option Append, insert, overwrite, lift, and ripple delete editing on the timeline 3-point editing Hide, mute, and lock track controls Multitrack timeline with thumbnails and waveforms Unlimited undo and redo for playlist edits including a history view Create, play, edit, save, load, encode, and stream MLT XML projects (with auto-save) Save and load trimmed clip as MLT XML file Load and play complex MLT XML file as a clip Drag-n-drop files from file manager Scrubbing and transport control Video Effects Video compositing across video tracks HTML5 (sans audio and video) as video source and filters 3-way (shadows, mids, highlights) color wheels for color correction and grading Eye dropper tool to pick neutral color for white balancing Deinterlacing Auto-rotate Fade in/out audio and fade video from and to black with easy-to-use fader controls on timeline Video wipe transitions: bar, barn door, box, clock (radial), diagonal, iris, matrix, and custom gradient image Track compositing/blending modes: Over, Add, Saturate, Multiply, Screen, Overlay, Darken, Dodge, Burn, Hard Light, Soft Light, Difference, Exclusion, HSL Hue, HSL Saturation, HSL Color, HSL Luminosity. Video Filters: Alpha Channel: Adjust, Alpha Channel: View, Blur, Brightness, Chroma Key: Advanced, Chroma Key: Simple, Contrast, Color Grading, Crop, Diffusion, Glow, Invert Colors, Key Spill: Advanced, Key Spill: Simple, Mirror, Old Film: Dust, Old Film: Grain, Old Film: Projector, Old Film: Scratches, Old Film: Technocolor, Opacity, Rotate, Rutt-Etra-Izer, Saturation, Sepia Tone, Sharpen, Size and Position, Stabilize, Text, Vignette, Wave, White Balance Speed effect for audio/video clips Hardware Support Blackmagic Design SDI and HDMI for input and preview monitoring Leap Motion for jog/shuttle control Webcam capture Audio capture to system audio card Capture (record) SDI, HDMI, webcam (V4L2), JACK audio, PulseAudio, IP stream, X11 screen, and Windows DirectShow devices Multi-core parallel image processing (when not using GPU and frame-dropping is disabled) DeckLink SDI keyer output OpenGL GPU-based image processing with 16-bit floating point linear per color component ShotCut 25.07 changelog: Added a Whisper.cpp (GGML) model downloader to the Speech to Text dialog. A model is no longer included in the download and installation reducing their sizes. Improved the System theme to follow the operating system palette on Windows (darker and more contrast), and improved its appearance on macOS dark mode. Added Settings > Theme > System Fusion that combines the operating system palette with the monochrome, symbolic icons of the Fusion themes. Added an Outline video filter that uses the input alpha channel--useful with rich text or assets with a transparent background. This means that, like Drop Shadow, it will not work as expected when used after a text filter on a video or image clip. Rather, you must use a text clip (transparent color generator with text filter) on an upper track. Other New Features Added the ability to drag the waveform peak line to adjust audio gain. Added Settings > Timeline > Adjust Clip Gain/Volume to turn off the above. Added rolling an edit/trim to Timeline: Hold Ctrl (command on macOS) while trimming to simultaneously trim the neighbor clip. Added a Soft Focus filter set. Added Audio/Video duration to the Slideshow Generator dialog, defaults to 4 hours. This facilitates using Slideshow Generator to make transitions between everything when including both video and images. (It still respects the source duration and in & out points; duration here is a maximum.) Surround Sound Mixing Improvements Added fader and surround balance to the Balance audio filter if channels > 2. Added Channels toggle buttons to many audio filters: Band Pass Compressor Delay Downmix Equalizer: 3-Band Equalizer: 15-Band Equalizer: Parametric Expander Gain/Volume High Pass Low Pass Limiter Mute Noise Gate Notch Added support for 4 channels in the Copy Channel audio filter. For example, now you can: Copy stereo music to the rear channels and use the fader in the Balance filter to reduce its volume, Downmix spoken word into the center channel and apply a Band Pass filter to it, and Route music or sound effects to the low-frequency channels and apply a Low Pass filter to it. Other Improvements Changed the default Export > Audio > Rate control to Average Bitrate for AAC, Opus, and MP3. Added the ability to add/use multiple Mask: Apply filters. Added support for Scrub While Dragging to trimming on the timeline. Added hold Shift to ripple-trim when Ripple is turned off. Added French (Canadian) and Lithuanian translations. Fixes Fixed Mask: Apply with multiple Mask: Simple Shape (broke in v25.05) Fixed exporting projects containing only Generator clips on Windows (broke in v25.05). Fixed converting 10-bit full to limited range (broke in v25.01). Fixed dropdown menus using Settings > Theme > System on Windows. Fixed Balance and Pan audio muted channels if audio channels > 2. Fixed Export > Use hardware encoder fails with H.264 on macOS 15. Fixed Properties > Convert or Reverse for iPhone 16 Pro videos with Ambisonic audio. Fixed a single frame fade out filter would either mute or make black. Fixed repairing a project (e.g. broken file links) with proxy turned on. Fixed doing Freeze Frame on the first frame of a clip. Download: ShotCut 25.07 | Portable | ARM64 ~200.0 MB (Open Source) View: Shotcut Home Page | Other Operating Systems | Screenshot Get alerted to all of our Software updates on Twitter at @NeowinSoftware
    • Win8 still takes the crown though in terms of worst Microsoft OS which all boiled down to it's horrible interface upon release as it was actually difficult to do even basic stuff. I remember trying it in a VM early on and it was a chore doing the basics we have had for ages and I quickly dumped that and never bothered with it again. in fact, prior to Win11 it was the only OS from Microsoft I have never used/had on a real machine and I have been using windows from Win v3.11 in mid-1990's through Windows 10. basically Win v3.11, 95, 98, Me, 2k, XP, 7, Vista, 10. but putting Windows 8 aside, I would probably place Win11 next in line (lets start from WinXP to date since that's basically when Windows got good and PC's pretty much went mainstream), but at least Win11 is not in the 'horrible' category as at least it's basic interface is normal. but if I ignore the interface, Win11 is a strong candidate, not only for telemetry and the like, but forced "requirements" which make people jump through hoops we should not have to all in the name of "better security", which personally I think is not enough of a boost to justify the forced "requirements". but one area you can tell Linux is faster is installing updates and, as a bonus, we generally don't need to reboot (short of like Kernel updates but those I am in no rush as my longest every main PC system uptime without a reboot was Aug 2023 until Jan 2025). but yeah, I suspect all of the background junk Windows has running does slow things a bit. p.s. speaking of that 'CachyOS', I used one of their custom Proton's (on Lutris) to get NTSync recently as while I usually use the more typical 'GE-Proton10-10' (this and '10-9' have NTSync support which was added recently. but 10-9 you have to manually enable where as 10-10 is automatic if it's available in the kernel to the system), I have one game which does not play back in-game videos with the Proton 10 series (you can hear audio but it's basically a black screen) but works in the 9 series and 'CachyOS' had a build from Jan 2025 that has NTSync, so I used that and it worked. I had to use 'PROTON_USE_NTSYNC=1' though since it's not enabled by default (along with 'sudo modprobe ntsync', or setup a udev rule etc if you want it to work in reboots without needing to do that command). one can see NTSync is working through MangoHud if you setup 'winesync' (just add that entry to "~/.config/MangoHud/MangoHud.conf") in the configuration file for ManngoHud or if you want to directly see it in proton log I did 'PROTON_LOG=1', which then creates a log in the Home folder which, at least on GE-Proton10-10, creates 'steam-default.log' and in that shows "wineserver: NTSync up and running!" where as if you don't it will generally show "fsync: up and running."
    • Riverdale... in space? Hope not.
    • Then why didn't Apple upstream their feature?
    • Unix is in fact not open source.
      Lokmat Rajasthan earned a badge
      TheRingmaster earned a badge
      smileyhead earned a badge
      K V earned a badge
      K V earned a badge
      177
      123
