Help finding out AMD A10 CPU temperature
I am trying to find out my CPU temperature, I have a quad core AMD A10 5700, I installed a free product called HWMonitor for this and it shows lots of data but not the four cores temperatures, instead it shows me a single core called "package".
Anybody can tell me if this is because the CPU has a graphics card integrated or how to find out each core temperature?
Thank you
PS: Screenshot attached, see where it says "Temperatures">Packages
  On 30/11/2013 at 00:43, Hum said:
Not all motherboards have temperature sensors, so you might not be able to tell.
I'm guessing 'package' is the core temps -- the highest figures.
127 F, being the average.
Temp sensor of the motherboard has nothing to do with the temp sensor of the CPU.. And yes OP.. See AMD A10-5700, then see "temperatures" under that? That is your Current, Min and Max CPU temps.
OP Asked.
Then I said, this, because you clearly implied that the motherboard temp sensor had something to do with the CPU temp sensor:
So don't try to play it off as though you knew what you were talking about with:
  On 30/11/2013 at 01:00, Hum said:
DUH :laugh:
Not trying to be a jerk here, I just don't like it when people give clearly misleading information.
Based on what was said here: http://www.alcpu.com/CoreTemp/howitworks.html; I checked the AMD programmer manuals and I think there is only one package sensor for APUs (either that or the documentation is really horrible... it actually is pretty bad tbh).
See:
http://developer.amd.com/wordpress/media/2012/10/254811.pdf
http://developer.amd.com/wordpress/media/2012/10/42301_15h_Mod_00h-0Fh_BKDG1.pdf (Your processor supposedly falls under this category).
Thank you everyone for the advice.
Do I deduct it correctly that because AMD A10 is an APU and not a stand alone CPU I will never see temperature for each separate core?
I was confused because I used to have an Intel quad core before and temperatures using the same program were dispalying each separate core, I had not taken into account that the A10 is a APU with graphics.
  On 30/11/2013 at 17:00, snaphat (Myles Landwehr) said:
I forgot to answer the other part of the question -- A10-5700 is an APU and that GPU listed is integrated on die.
that is odd. I'm running a AMD combo A8 3520M with a 6620HD APU... they down graded your APU for basically a superior CPU to mine. :huh:
Not mine :-), but the OPs. I imagine it has something to do with catering to different segments of the market.
Even the older series AMDs (non-APUs) didn't have per-core temperature sensors from what I've been reading (disclaimer: I haven't owned an AMD processor in ages). If they had decided to they could have provided sensors for each core and the on-die GPU. It may well have to do with the on-die transistor area. It might not have distinct regions used for core or for the gpu; in which case it doesn't really make sense to have more than 1 sensor for the entire package.
ugh... sorry. jumping from putting up the christmas tree and here
  • Like 1
