Sound Distortion on High CPU Ticks
I have been getting weird pops and lagged music for a few weeks on my computer. Whenever there is a high tick on my CPU i get a sound distortion and it makes browsing the web and listening to music a little annoying. Any time i open a new tab or a flash element loads the music distorts.
PC Specs.
Windows 8.1u1 x64
Core i7 (Quad Core)
8Gb DDR3 RAM
Dual GT650M in SLI nVidia GeForce Driver Version: 337:88
RealTek Audio Driver Version: 6.0.1.6886
Laptop Model: Lenovo IdeaPad Y500
https://www.neowin.net/forum/topic/1218363-sound-distortion-on-high-cpu-ticks/
Prolly similar to my Thinkpad T410s. It seems like the Audio chipset and USB shares some portion of the PCI express bus or something. Whenever I'm copying files over WIFI and it maxes out, my audio stutters and the Trackpad doesn't work (sometimes) while the Trackpoint still works fine (prolly connected via PS/2 old serial lanes instead).
Got a T440s now and that doesn't seem to happen anymore but I haven't really tested it yet.
any chance you are overclocking your CPU (or anything else)?
because i remember once in a while my old motherboard, which i had the CPU overclocked on, would have a quick burst of sound distortion or stutter here and there and it was annoying and i am pretty sure it was due to overclocking a bit to much in my case even though the system was stable besides those occasional glitches.
I always get Realtek drivers from Realtek (Realtek actually recommends not doing that, but I often have a lot more problems with the older drivers from the OEMs than the newer ones they offer.)
Might also go for the Intel chipset drivers, if you haven't.
Not over Clocking at all.
  On 18/06/2014 at 00:08, Zlip792 said:
Tried updating Realtek Audio Driver to 6.0.1.7246 (Realtek HD Audio Driver 2.75)?
I am updating now to the newer version of the driver. I was using the latest version on the Lenovo website.
  On 18/06/2014 at 01:04, Shiranui said:
Keep an eye on the
Windows Audio Device Graph Isolation
process.
Kill it in taskman (you will have to restart whatever you are using to play your music) and see if things calm down a bit.
There is no such service running on my computer.
  On 18/06/2014 at 00:38, HawkMan said:
Seems like dcp latency issue.
how would i check and test this idea?
I have done two things since i got home.
Installed the latest Nvidia Driver (340.xx)
Rebooted
Uninstalled RealTek Driver
Rebooted
Installed Realtek Driver 2.75
Rebooted.
and it appears to be all better now. (for the time being) lets see how it does in a day or so :D
Thanks for the ideas.
