- 0
Pseudocode help.
Asked by
lolman,
Recently Browsing 0 members
Posts
By +sphbecker · Posted
I assume he would make the same statement in those cases as well. -
By Neonix1 · Posted
Looks like an alien. Probably is an alien. First it was aaaaallll Azure and drop everything else. Now its aaaaallll AI and drop everything else. Narrow-minded. I really loathe this guy. He's good for shareholders but absolutely nothing else. Dry as desert sand and evil to the bone. -
By seta-san · Posted
Don’t care about a wrestling union. No normal person should care. -
By naap51stang · Posted
Limassol, Cyprus. Just south of Turkey. NOT Russia. -
By goretsky · Posted
Hello, Given the reports of Chinese Mini PCs shipping with malware, I would recommend wiping the machine and performing a clean install of Windows on it before use. From what I can infer from the reports, the Mini PCs that shipped with malware were not the result of targeted purposeful action on the part of the device manufacturers (which is something that has happened with low-cost Android smartphones and TV boxes from China) but rather due to lax security in the manufacturing process. Getting back to the subject at hand, there are a few steps you will want to go through before wiping the Mini PC: You can start preparing even before the Mini PC arrives. Once you have ordered it and know the brand and model, go to the manufacturer's website and download all of the latest device drivers, BIOS (UEFI) firmware updates, machine-specific software (if any), and manuals. Many Mini PC manufacturers do not do a lot of customization of their device drivers, just shipping whatever device drivers the the silicon vendors provide. I still recommend downloading them, though, just in case there are some customizations or for initial install since those are the drivers you know the manufacturer validated for the Mini PC. Store these in a safe place, so you have them ready when the Mini PC arrives. Use Microsoft's Windows Media Creation Tool to create an installation USB. You can also create a directory on installation USB--like C:\DRIVERS\ or whatnot--and store the extracted device drivers there in case you need them while or after installing Windows. Once the Mini PC arrives, and you have your Windows installation USB available, you can proceed with wiping the PC and doing the clean install. Here's how you do that, step-by-step: Check the computer and make sure you know how to boot it from a USB flash drive (may be a specific key you have to press when the computer is powered on, or a change to the BIOS (UEFI) firmware settings. The PC may tell you what key combination you need to press to boot from another drive, or the manual for the PC may it. Plug the USB flash drive into the computer and power it up using the means to have it boot from the Windows install USB. Once the computer finishes booting, it should be at a Windows installation screen. Do not agree to any prompts, copyright licenses, or click on any buttons. Press the Shift + F10 keys together to open a Command Prompt. Run DISKPART to start the command-line disk partitioning utility. The command line prompt will change to DISKPART>. At the DISKPART> prompt, type LIST DISK to get the numbers of all drives installed in the system. Make a note of what number is assigned to what drive (if the Mini PC has more than one drive). At the DISKPART> prompt, type SEL DISK n where n is the number of the drive containing Windows. At the DISKPART> prompt, type CLEAN and this will erase the GPT/MBR code from the beginning of the drive. *WARNING:* After performing the clean operation, the drive now be blank/erased, and everything on it will be gone (all files, etc.). You can exit DiskPart and just continue with the Windows installation as you normally would. If needed, you can install the device drivers you put on the Windows install media to get your network connection up and running, and from there run Windows Update to get the operating system and device drivers up to date Regards, Aryeh Goretsky
Recent Achievements
cac1lll earned a badge
Falcon.ai earned a badge
EYEREX earned a badge
Electronic Person earned a badge
Popular Contributors
Tell a friend
lolman
Okay, so I've been doing practice with pseudocode in order to get ready for the exams at school but I'm stuck on one of the practice tasks and am scared that if I can't pass this I wont be able to even do the actual exam itself.... keep in mind I'm very new to pseudocode.
Okay so the task is to:
Task
Basic requirements: You are to write the pseudocode for a random quotes program. Quotes stored in an array are to be randomly chosen and displayed in the output window. You must use at least three functions:
One that gets a random quote
One that displays the quote
The draw function from which other, but possibly not all, functions are called.
Here is a link to a video clip that shows a possible more advanced version of the coded up program, displays inspirational quotes: Possible program
As can be seen a random inspirational quote is displayed every half-second or thereabouts from a range of set quotes. The font is chosen randomly from a range of fonts, and a font size is likewise randomly chosen from a range of sizes. In addition they are in different colours chosen at random from a range of colours, and they all fit within the output window.
Note: It is more likely that you will get a better grade if you choose to go beyond the basic requirements of the program.
This is what I've gotten so far:
https://www.neowin.net/forum/topic/1226101-pseudocode-help/Share on other sites
3 answers to this question
