Hi
I really want to remove the windows taskbar and just use objectdocks but I have a problem... Can I move the items from the system tray to obectdock somehow? I really need mirc and msn to move up and some other small things...
Is it possible? I am running samurize as well, is there a way maybe to show all the system tray items in samurize?
https://www.neowin.net/forum/topic/123334-objectdock-and-system-tray/
They didn't put a tray in ObjectDock because that functionaly exists in Stardock's commercial product ObjectBar. I don't know for sure if there's another program that's just a (free) tray replacement. If there is, I'd like one too.
I do know that you can tell mIRC *not* to minimize to the tray, and you can tell MSN Messenger not to run in the background and just minimize it instead of closing it... but that's not what you want to do. I would still want to have a visible tray instead of filling up my dock.
  Fredde87 said:
where can I find kk menu? I have googled it but I only found some stuff that has nothing to do with it :/
You can download kk menu from wincustomize HERE
Unfortunately this docklet is shareware, but it does have the system tray in it, as older versions that were free (which I'm using) did not. If you wanna pay $10 for a docklet go ahead, cuz I sure wouldn't! :no: I'll keep running the free one, it's working just fine without the system tray!
