Hey, I must have messed something up somewhere along the line that wasn't a problem until now. Normal http addresses work fine, but numerical ones do not. This is a problem now because I need to connect to my router, and 192.168.1.1 doesn't work. I know it's not just the router, because I tried other IP addresses and got the same problem. Anyone know what's up?
https://www.neowin.net/forum/topic/125016-ip-problems/
No, and since it's going through a browser I don't think that's the problem. And I tried firebird/IE, and none of my network settings should be strange, it's just a simple ethernet connection.
One thing I'm thinking now is I've gotten this to work before, but since them I fiddled with shutting off some of XPs services. Would one of them be responsible for this problem?
https://www.neowin.net/forum/topic/125016-ip-problems/#findComment-1494610
  jbenhm said:
Whenever you go to a numerical address e.g. 192.168.0.1 or something, you MUST have http:// in front of it - otherwise IE will return a page not found error. So to access your router you MUST have http://192.168.1.1 - hope this helps.
-jbenhm
actually, no you dont HAVE to have http:// in front of it in ie... it will do it for you.
https://www.neowin.net/forum/topic/125016-ip-problems/#findComment-1494643
Depending on what type of router you have, you can probably get to the router's configuration by opening a telnet session to the router's IP. You could also try adding an entry to your computers hosts file, something like: "192.168.0.1 router.local" To track down the problem with your computer, try the command "telnet 192.168.0.1 80" If you get a blank command window, you are connecting to the router successfully via port 80, if not you'll get an error message.
https://www.neowin.net/forum/topic/125016-ip-problems/#findComment-1494680
I got an error message. I still can't figure out if it's me or the router, but I've set up a different router on this computer with no problem before.
I'm thinking its the router now, I booted up Redhat and still couldn't connect, which means it isn't any of my Windows settings.
https://www.neowin.net/forum/topic/125016-ip-problems/#findComment-1495783
Considering you get the same results in 2 different OS, I would have to agree that it's probably your router causing the problem. I would recommend unplugging any other devices from the router, unplugging the router's power supply from the power outlet, waiting about 30 seconds, then plugging the router's power back in with only your computer connected to it. If you get the same results, you might have to try the factory reset.
https://www.neowin.net/forum/topic/125016-ip-problems/#findComment-1496594
    • A 10% IPC boost is underwhelming for what is supposed to be a major generational leap. Unless it's accompanied by higher clock speeds, or the IPC boost is greater than 10% in games, I'm not sure that it will be enough to compete with Zen 5 X3D, let alone Zen 6 X3D for gaming. Single-core performance is super important and cannot be compensated with more cores, whereas the reverse is true, you can compensate for fewer cores with better single-core performance.
    • Been happy with Windows 11 myself even since first release in 2021, sure it hasn't always been perfect, but nothing is per say.. Issues i did have was minor ones, which is normal with any OS really. I still use Windows 10 at times on my unsupported Gaming Laptop, and i find myself using the Windows 11 Desktop more. Eventually replacing Gaming Laptop with a Windows 11 Compatible one somehow, someway this year or possibly next year at the latest, but its gonna happen--(May save all my Bing reward points except the 1000 to have extended support for 10) then work on getting quality Replacement hard)
    • Geez, this is dumb. I use my laptop sometimes in the dark when doing astrophotography to control my astro-PC... this explains why I have to keep entering my PIN when logging back in. So stupid. I can't see the keyboard in the dark, and I can't have lights everywhere to light it up because everything is very light sensitive (including my eyes!).
    • Naturally. I don't care about brand loyalty at all as it's all about price/performance/reliability etc (even what RejZoR said below is a great point to). basically bang-for-the-buck. because at the end of the day... one wants the cheapest possible price to maintain a certain minimum level of performance (or thereabouts). because generally after a certain point with CPU and GPU's the price starts to sky rocket without that much difference in performance where it really matters. p.s. historically I have bought more Intel CPU's and NVIDIA GPU's but I have had some AMD CPU's and one AMD GPU.
    • Both of these companies as well as Qualcomm and Apple need competition. Otherwise, they just coast. I don't prefer macOS, though I like some of Apple's hardware, but if anyone needs competition, it is Apple. Their prices are already outrageous and they need to have a reason to produce good hardware and at least keep prices remotely reasonable. (It is criminal what they charge for RAM upgrades especially.) Qualcomm needs to push AMD and Intel not to be so sloppy with the performance/efficiency aspect. Granted, AMD has been doing quite well in this respect considering they are not an ARM architecture. I personally want to have more options that truly compete with Macbook Air and Macbook Pro's on the Windows side. It is difficult to achieve what Apple does since they control the entire stack and that is fundamentally different for Windows PCs other than maybe Microsoft Surface PCs.
      Hartej earned a badge
      TsunadeMama earned a badge
      shaheen earned a badge
      Cole Multipass earned a badge
      Alexander 001 earned a badge
      182
      Skyfrog
      111
      Som
      106
