elliotng Posted January 30, 2002 Share Posted January 30, 2002 Hi all~!:) :D I am a C++ beginner Can I insert an icon with 32bit colour~? I can only create one with 16 colour:( :( :( :( Link to comment https://www.neowin.net/forum/topic/12647-c-icon-problem/ Share on other sites More sharing options...
0 Glowstick Posted January 30, 2002 Share Posted January 30, 2002 details would be appreciated, like what icon editor and what resource compiler? Link to comment https://www.neowin.net/forum/topic/12647-c-icon-problem/#findComment-103165 Share on other sites More sharing options...
0 elliotng Posted January 30, 2002 Author Share Posted January 30, 2002 Thank you for your reply first;) I am now using Visual C++ 6.0 The icon i want to insert was found on the internet. I have try to open the icon with iconxp and copy and paste it into the visual c++ icon editor, however, it cannot display correctly:sleeping: :sleeping: Pls help me~! Link to comment https://www.neowin.net/forum/topic/12647-c-icon-problem/#findComment-103239 Share on other sites More sharing options...
0 Glowstick Posted January 30, 2002 Share Posted January 30, 2002 I think VS6 just supports up to 256 colors. Edit it in an icon editor and add it as file to the resource file. I never used VS6 to create windows apps, so I'm just guessing. Link to comment https://www.neowin.net/forum/topic/12647-c-icon-problem/#findComment-103252 Share on other sites More sharing options...
0 elliotng Posted January 30, 2002 Author Share Posted January 30, 2002 I see, I have replaced the icon with a new one in the "res" folder. When I try to open the workspace in VS6, it fails to load the resource. I also rebuild it but still doesn't work. Anyway, thx for your help:) :) Link to comment https://www.neowin.net/forum/topic/12647-c-icon-problem/#findComment-103258 Share on other sites More sharing options...
0 dacris2000 Posted February 3, 2002 Share Posted February 3, 2002 edit ur icon in Paint Shop Pro save as BMP copy & paste that into GIF Movie Gear GIF Movie Gear is found at http://www.gamani.com/ File -> Export As -> ICO Hope this helps :D Link to comment https://www.neowin.net/forum/topic/12647-c-icon-problem/#findComment-107001 Share on other sites More sharing options...
elliotng
Hi all~!:) :D
I am a C++ beginner
https://www.neowin.net/forum/topic/12647-c-icon-problem/Share on other sites
5 answers to this question
