Installing wired home network under floorboards ... best method?
Recently Browsing 0 members
Posts
By Izlude · Posted
hi thanks for input. those two modems are supported thankfully. i really am leaning towards the b12 though since there's a few complaints of the cm3000 and its chipset (drops and whatnot), although those might just be vocal minority complaints. -
By Usama Jawad96 · Posted
A PDF or text file is all you need for Copilot to generate a PowerPoint for you in seconds by Usama Jawad Assistive AI is all the rage these days. In the past few hours alone, we have witnessed AI summaries on YouTube, context-aware text generation capabilities in Google Sheets, Gemini tools on the cloud, the availability of additional AI models with smarter defaults in Visual Studio, and chat summarization on WhatsApp. Now, Microsoft has detailed an upcoming Copilot capability in PowerPoint. Microsoft has outlined a streamlined approach to creating PowerPoint presentations within seconds using a PDF or text file, and a natural language prompt as input. Previously, you could just ground Word files for this purpose, so support for additional formats is certainly welcome. In order to generate a slide deck using Copilot, you can simply open a PowerPoint presentation in the platform of your choice and click the Copilot button. In the resulting Copilot pane, select the "Create a presentation from a file" option, which allows you to type in the name of a PDF or text file stored on the cloud or browse for files in OneDrive or SharePoint manually using the "Attach cloud files" button. You can then refine your prompt by adding details about items that you'd like Copilot to focus on and click the "Send" button. This will generate the slide deck which you can rearrange or add more topics to, before you create the final version of the presentation. Of course, this is a particularly useful feature in many scenarios including those which require you to create a slide deck based on some detailed documentation that you have already completed. That said, it's obviously worth vetting any content that Copilot creates, since data inaccuracy is still a concern when it comes to AI models. This feature is available to Insiders across PowerPoint for web, Windows, and Mac for the following versions: Windows: Version 2409 (Build 18025.20000) or later Mac: Version 16.88 (Build 24082514) or later That said, you do need an Enterprise Copilot license in order to utilize the AI assistant in this way. -
By excalpius · Posted
>For instance, if you are watching a tutorial, you could ask for a summary or even for a quiz on the main points. At that point, the content creator should get their cut, Google. Instead: >If people are getting everything they need from a summary without ever clicking through, there's not much reason to watch the actual video. That means fewer views, less watch time, and less money. Do content creators get to write their own summaries or turn off Google's summary content thievery? Somehow I doubt it... -
By Xenon · Posted
I know with my isp they will only support certain models. You might want to check with them, -
By +sphbecker · Posted
ahh...I guess I misunderstood what it was saying.
Recent Achievements
jfam earned a badge
TheRingmaster earned a badge
Kavin25 earned a badge
Leonard grant earned a badge
pcdoctorsnet earned a badge
Popular Contributors
Tell a friend
