- Click refresh
- Refresh the page
- Refresh the page
- Refresh the page
Brandon H Supervisor
Hello
I am trying to set up what I am sure is a simple rule but I have not used the Substring and Translate functions before so am unsure of the correct formatting on what I need.
The initial field has the now() function so it displays the date/time. What I'd like the rule to do is change the fields value to a 6 digit string using the month and time as such:
2016-04-22T11:53:21 would become 041153
I know this can be done using the Substring and Translate functions but have not used them myself before. Any help would be greatly appreciated
https://www.neowin.net/forum/topic/1295562-infopath-substring-and-translate-help/Share on other sites
1 answer to this question
