Please help with my jquery issue, 2 scripts together
I'm trying to get 2 jquery scripts to both work on the same page. One just shows text over a thumbnail when it's hovered over, the other just expands the thumbnail when it's click on. I'm so close I can almost taste it but I'm totally stumped now :/  To make things easier, here is a tiny .zip so you can see what I'm doing. http://www.classicdragons.org/TEMP.zip
Just open temp.html and you can see that the hover over jquery works perfectly, but clicking does nothing. Then just remove this from temp.html :
$(function() {
    $('img').hover_caption();
...and you will see that the hover jquery is now of course broken but now the click to expand the thumbnail jquery works.
I'm desperately trying to get these to work together! Please help, I would really appreciate! Thank you in advance!!!!
Alex
14 answers to this question
Ok, so far it appears that the overlay is getting in the way of letting you click the actual image when it is created. I am still looking.
EDIT: What about just changing the height of the caption overlay so it doesn't take up the whole image?
Edited by winlonghorn
With help from winlonghorn, he has helped me so the hover over works and when I click on the image, it brings up the viewer. However the full image doesn't display in the viewer.
I have updated the link in my OP to reflect where I stand currently. I'm so close now! Just need to figure out why the image doesn't display in the viewer.
Any help much appreciated! Thanks!
The reason that you don't see the full image is because of this code in /css/jsgallery.css:
.jsgallery-container #jsgall_imageContainer:before {    /* create a full-height inline block pseudo=element */
    content: ' ';
    display: inline-block;
    vertical-align: middle !important;
    height: 100%;
That code is inserting a block above your full size image in the viewer that is the full height of the page, thus the full image is pushed off of the screen. Removing that style block makes your full-size image visible.
When I remove that, the image appears, but then the full size image still has the shadow covering it until I move the courser off screen. Plus clicking anywhere doesn't remove the full size, it just reloads it.
But that is a step forward, thanks!!!!!!! I've been stuck on this for weeks lol.
The reason that clicking on the full-size image doesn't close the full-size view is because you've setup the gallery script to run whenever an <img/> is clicked. Since the full-size image is rendered as an <img/> tag, clicking on it actually runs the gallery script again.
I simply want to be able to mouse over an image (it's an art gallery web page with dozens of thumbnails on a page), the mouse over display a description of the image, then if clicked, the full size image shown. Then clicking anywhere will exit out of the full image view, or clicking next or swiping next when in full image view go to the next images in full size.
Thanks for any help, this is really challenging me, not my programming expertise at all :/
Edited by anguilla1980
    • Oh no... here we go again. Tha same sh*t that happaned to Mail & Calendar...
    • I too have worked with pro gear for decades and so I found the interface to be unintuitive from both the pro and casual side (a rare "accomplishment" by what are obviously otherwise skilled coders, hehe). I eventually got it to work, thanks for offering, but I found other compatibility issues with my own use case, so I just dropped it entirely. Right now, I just use an analog line out/line in approach which works as expected across all usage scenarios. With both machines on the same power block/outlet, I'm not getting any analog hum or hiss. My next step will be to try the updated Multiplicity 4 when a bug, addressing this very issue unfortunately, is resolved. Knowing Stardock, that could be tomorrow or five years from now, so I check back every few months to see it it's fixed and I want to upgrade. Again, thanks for offering to help.
    • We recognize that performance can use some improvements, and we continue to work on improving it. However, it's worth noting that massive performance improvements don't happen overnight, they take a lot of work and effort, and in most cases, the improvements are more noticeable when you compare across several updates. That said, Files is open-source and everyone is invited to help with these efforts 🙂
    • A lot of effort has gone into improving stability and Files Preview now has a 99% crash free rate. These improvements will make their way to Files Stable when v4 is released later this year. If you're still experiencing issues, please report them on GitHub or Discord so we can track them properly.
      Snake Doc went up a rank
      nobody9 earned a badge
      Ricky Chan earned a badge
      leoniDAM earned a badge
      Ian_ earned a badge
      137
      115
