This is a fresh install of Windows 10 Education.  When I opened Edge today to go to a website, I typed 888.com (it will be blocked normally in our content filter, so it prompts to login), but it just did a search for "888.com".  I could even type http://888.com and same result.  I tried this with another site and got the same result.  The I tried neowin.net, and that worked fine.  I saw the icon next to the URL turn into magnifying glass for the searches and and a globe for NEOWIN.
My question is why does it do that, and how do I get it to stop?  The desktop version of IE works just fine.
https://www.neowin.net/forum/topic/1297806-edge-issue-when-entering-urls/
  On 18/05/2016 at 03:30, Eric said:
It could be a bug. It used to be that hostnames couldn't start with a number but it was changed at some point.
Expand
That's interesting.  I hadn't used Edge much up until today.  Just here and there and it's been a while.  Just haven't installed any browsers yet and trying to evaluate using it for next school year.  Most use Chrome anyway, but I'll keep an eye on it and ask is MS forums.  Thanks for input!
your filter may not understand the edge browser, it may be browser based.
in my barracuda web filter, if using the remote monitoring software I must tell it what executables/browsers to monitor.   Internally it is invisible/pass through to the network so it doesn't matter.
All I am saying is that I do not know how your webfilter works and it is possible that it could be browser based and that it really isn't a browser issue as it is a webfilter issue with edge.
It's using transparent filtering right now.  We have a proxy available, but I don't have GPO set up yet as we're moving to AD from Novell.
We do have a login on blocked sites, and my login is allowed everything except porn, basically.
I would think with transparent filtering and my login allowing most everything, I would have an issue, but there could be something there.  I know there was an issue a while back with Edge (and Apple with iOS9) where the splash page wouldn't open properly.
    • Darwin Mach Kernel/ BSD. Which is both open source.
    • You mean BSD. The UNIX kernel is not open source.
    • I have been on Linux Mint full-time since Jan 2019. while there is a learning curve, it's worth it if you can make the switch, which I can. I mainly browse web, play some games (generally Lutris(Windows games), or through emulators (MAME/Mesen/Flycast etc) etc), and use a small amount of Windows programs (Foobar2000/7-zip/WinRAR/ImgBurn etc) etc. it's nice to dodge the bloat/BS of Windows as you can really feel Linux is all around faster, especially certain things. p.s. recently I enabled NTSync for games since Linux Mint recently offered the 6.14 kernel, which has NTSync support (it's not enabled by default though but you can enable it temporarily for your current boot of the OS through 'sudo modprobe ntsync')
    • A rotten article full of handwaving of anti-consumer practices. Aside from the fact that no, not even close to every piece of major software collects information about its users, ethical developers make such telemetry opt-in and allow it to be completely disabled. To use KDE Plasma as an example, you're shown a greeter upon first boot that gives users the option to send the developers telemetry, with the default being off and 'off' actually meaning off. Windows 10 has never offered that capability - only a promise that Microsoft will slurp up less of your data if you spend time tweaking 50 different privacy settings. There is still absolutely no way to completely opt out of sending Microsoft telemetry in any version of Windows 10 (or 11, naturally). Even using group policy in Enterprise editions only allows you to reduce telemetry to the bare minimum. Home-focused editions don't even get that option. Articles like this dismissing user privacy concerns as "FUD" are a part of the reason Microsoft felt confident enough to go so much further with Windows 11. I guess you get what you deserve in that respect. Personally, I finally made the move to Linux after 15 years or so of dabbling with it, but never really considering a permanent switch. Enjoy your bright, shiny Windows future. You asked for it, after all.
      smileyhead earned a badge
      K V earned a badge
      K V earned a badge
      CarlosABC earned a badge
      solidox earned a badge
      172
      122
