Removing IE from system
That's what Microsoft say, but in 1999, Shane Brookes disproved this with his 98lite software.
Some applications require the HTML engine of IE, so I think you need the DLL files for them to work. XPlite might remove it in a way that allows applications to use the engine though.
yeah, but if you click the windows update link guess what opens. what i wanna know is how do i remove the stupid IE icon from my desktop. in the display settings thing i have it set not to show, and in tweatui i have it set not to show, and i did the thing listed above which should just remove all the icons and shortcuts to it, but it came back a couple of weeks ago and i can't get rid of it. :(
Do you really want to remove Explorer? Just delete these files from the system32 folder:
The 56 files in System32 XP installs for Explorer.
actxprxy.dll
asctrls.ocx
atl.dll.lnk
browsewm.dll
cdfview.dll
ckcnv.exe
cryptdlg.dll
cryptext.dll
cryptnet.dll
csseqchk.dll
dispex.dll
dxtrans.dll
hlink.dll
homepage.inf
ie4uinit.exe
ieakeng.dll
ieaksie.dll
ieakui.dll
iedkcs32.dll
iepeers.dll
iesetup.dll
imgutil.dll
initpki.dll
inseng.dll
isign32.dll
jobexec.dll
jscript.dll
jsproxy.dll
licmgr10.dll
mobsync.dll
mobsync.exe
msencode.dll
msidle.dll
msieftp.dll
msnsspc.dll
msr2c.dll
msr2cenu.dll
msrating.dll
mssign32.dll
mstime.dll
msxml.dll
msxml3.dll
occache.dll
plugin.ocx
pngfilt.dll
proctexe.ocx
regwiz.exe
regwizc.dll
scrobj.dll
sendmail.dll
simpdata.tlb
sysinv.dll
t2embed.dll
tdc.ocx
webcheck.dll
xenroll.dll
yes, do that. then run any program that connects to the internet. most likely either the program or windows will crash. if you don't like IE, just don't use it. most of the applications out there use IE though, and when one of them tries to, stuff happens ;)
Nonsense.
Just install 98lite/2Klite/XPlite and rip that mutha out.
Use caution, though. Things have a habit of busting if you remove IE.... in particular, I found that the ability to show/hide XP's system tray icons is removed along with IE, Windows Media Player may not automatically download codecs correctly and you can definitely kiss Windows/Office Update goodbye.
I'm not sure I would call the list of files I gave to remove IE nonsense...unless of course you are calling XPLite nonsense, too. That list of files is the exact files XPLite removes. I kid you not.
If you only want to remove IE with XPLite, I just saved you the money it would cost to purchase the program.
