- Click refresh
- Refresh the page
- Refresh the page
- Refresh the page
Steven P. Administrators
Short answer: open the Windows\System 32\Drivers\Etc\Host file with Notepad and add this at the bottom (on a new line) 92.240.234.122 api.opensubtitles.org
Long answer(s) https://github.com/exebetche/vlsub/issues/143 the above fix worked for me
the change http 1.1 to http 1.0 in a Hex editor did not.
https://www.neowin.net/forum/topic/1312942-vlsub-not-working-in-vlc-player-heres-a-fix/Share on other sites
4 answers to this question
