Using a touchscreen as a second monitor?
Recently Browsing 0 members
Posts
By Copernic · Posted
Bulk Rename Utility 4.0.1.0 by Razvan Serea Bulk Rename Utility is an easy to use file rename program (a.k.a. file renamer). Renaming multiple files and/or multiple folders has never been easier. It has a small memory footprint so it can be left running all the time without consuming all your memory. Add date/time stamps, replace numbers, insert text, convert case, add auto-numbers, process folders and sub-folders... plus a whole lot more! Bulk Rename Utility allows you to easily rename files and entire folders based upon extremely flexible criteria. Bulk Rename Utility is free of charge for personal, private use, at home. To use Bulk Rename Utility within a business entity, company or for commercial purposes, a commercial license is required. Bulk Rename Utility key features: Rename multiple files quickly, according to many flexible criteria. Rename files in many ways: add, replace, insert text into file names. Convert case, add numbers. Remove or change file extensions. Check the detailed preview before renaming. Add "Bulk Rename Here" to the Windows Explorer for quick access (optional). Directory recursion - process files/folders in all sub-directories too. Use Regular Expressions to rename files / folders. Use Javascript to rename files / folders. Rename files from an input text-file list (CSV). Create an Undo batch file. Log all renaming activity to a log file. Change file and folder date/timestamps (created, modified, accessed). Change file/folder attributes (hidden, read-only, archived). Rename photos using EXIF metadata (i.e. "Date Picture Taken", "Resolution" and other information embedded in all JPG photo files). Rename MP3 files using ID3 tags (a.k.a. MP3 ID3 tag renaming). Rename files using Windows File Properties (e.g. length, width, height, rate, publisher, title, etc). More than a hundred attributes for different file types. Change EXIF date taken information. Bulk Rename Utility 4.0.1.0 changelog: Added the ability to open a .bru file by double-clicking it while Bulk Rename Utility is already running. Added a popup error message if a .bru favourite file cannot be accessed when opening it. Added a popup error message if a .bru favourite file cannot be saved. Increased the supported line length in .bru files. Fixed an issue where the “Scanning... please wait” message was never dismissed when dragging a folder into Bulk Rename Utility. Fixed a crash when starting Bulk Rename Utility and auto-opening a .bru file that is no longer available Download: Bulk Rename Utility 4.0.1.0 | 11.5 MB (Free for personal use) Download: Bulk Rename Utility Portable | 20.7 MB View: Bulk Rename Utility Home Page | Screenshot Get alerted to all of our Software updates on Twitter at @NeowinSoftware -
By eilegz · Posted
nope only 21h2 sadly. -
By Co-ords · Posted
just remove the junk. Plenty guides online to show you how. -
Fort Firewall 3.18.8 by Razvan Serea Fort Firewall is a simple and effective firewall application designed for Windows 7 and later versions. It offers a range of features to help you control and monitor your computer's internet access. With Fort Firewall, you can filter network traffic based on various criteria, such as network addresses, application groups, and even specific service names like SvcHost.exe. This allows you to have more control over which applications can access the internet and what type of data they can send or receive. One of the key features of Fort Firewall is its ability to limit the internet speed and usage for specific application groups. This can be particularly useful if you have certain applications that tend to consume a lot of bandwidth, such as video streaming or file sharing software. By limiting their access, you can ensure that other applications still have enough bandwidth to function properly. Fort Firewall also keeps track of your computer's internet traffic statistics, allowing you to see how much data has been sent and received over time. This information can be displayed in graphical form, making it easy to understand and analyze. Under the hood, Fort Firewall uses the Windows Filtering Platform (WFP) to monitor and control network traffic. This ensures that it integrates seamlessly with your Windows operating system and provides a reliable and efficient way to manage your computer's internet security. Fort Firewall 3.18.8 changelog: Driver: Fix connection's direction on reauth (#597). Driver: Rework paths handling (#593). UI: Show alert popup on startup too. UI: Update SQLite to 3.50.3 Download: Fort Firewall 64-bit| 6.3 MB (Open Source) Download: Fort Firewall 32-bit | ARM64 View: Fort Firewall Website | User Guide | Screenshot Get alerted to all of our Software updates on Twitter at @NeowinSoftware -
By thartist · Posted
Ahhh, the file transfer oobe assistant... Chef's kiss!
Recent Achievements
Amadou earned a badge
TheRingmaster earned a badge
smileyhead earned a badge
K V earned a badge
K V earned a badge
Popular Contributors
Tell a friend
