I'm trying to do some research on what the best solution for replacing Dropbox with an onsite storage which would be sharing big files aka Adobe files like PSD, INDD, AI and PDF. These files will need to be shared with 4 different graphic designers. The solution they have now is using Dropbox Teams which is not bad way to go but you need to have a 1TB SSD drive on the computer and files don't link correctly because Dropbox is under your user directly and that changes the path of each link which breaks the chain of the file that you are linking to on a different computer when someone opens it. The storage needs to be able to have a user and password for about 20 people to get on to and not just one user and password to access the storage. To make sure who is getting on the storage. They do have a server bay onsite and everything is wired so speed is not an issue. Would also like a solution for people who need to get on the storage when they are offsite. Plus would like to know what the best backup solution for the onsite storage which will backup once a day or week on the cloud.
I have work with Drobo in the past but that was over 9 years ago. I hear some good things about Synology know much about it. Thanks!
Expand
You do not have to do it that way you can create dropbox folder anywhere you want.  Mine is d:\dropbox for example.
So is your goal to not have the files directly on the users computer any longer and just access the site storage directly be it they are onsite or remote?
Expand
Just to point out that it will be shared on Mac and PC so that open will not work. Yes, we don't want all the files on all the computers. We want it on on storage and people can access it like a drive instead of downloading the whole marketing files and have dropbox keep updated all the computers when something has changed. It's not a good solution for the company is doing.
Well then just any share works..  SMB, NFS, etc.. That all your OSes can use If you don't have a server then sure any NAS would work..
As to remote access - VPN in.. Keep in mind that direct access to files over a vpn can be problematic all depending on speed/latency of the end users connection.. If the files are LARGE not a good idea to work on them directly over the remote connection.. Would be best in such a scenario to have the user copy the file to their machine.. Edit what they need too remotely, then upload it back..
    • ...so more bloat is added (that naturally is always running in the background, using resources) that will report that you have a lot of bloat (and also a few more ads were also added but that has nothing to do with anything, right...).
    • Thank you for replying! Is MP600 also good? Where I'm looking they don't have MP700. I was also looking at Corsair T500, that comes with heatsink.
    • As someone who was born in 1980, I’m feeling this.
    • Amazon Deal: This Vifa Stockholm 2.0 is one of the best sounding bluetooth speakers by Sayan Sen A few days back we covered some great JBL bluetooth speaker deals across several of its popular models. The discounts are still live and you can check them out in this dedicated piece. Meanwhile for those who prefer more powerful home cinema sound systems, Nakamichi and Samsung are offering the Dragon and Shockwafe models, and the Q-series models, respectively, at their best ever prices. However, if you are someone who is looking for a bit of both, the portability of a bluetooth speaker and the fidelity of a good sounding hi-fi system then the Vifa Stockholm 2.0 Bluetooth Soundbar is something you should look at as it's currently a nice deal (purchase link under the specs table below). While you are not getting a subwoofer with the Vifa Stockholm as it is a 2.0 system, Vifa promises lows down to 42 Hz at +3dB and that should be pretty good for a device lacking a dedicated bass unit; it does pack passive radiators to help with the bass. The Stockholm 2.0 is praised for its sound quality (SQ) and one of the reasons behind it is becasue it has three-way drivers. The technical specifications of the Vifa Stockholm 2.0 Bluetooth Soundbar are given below: Specification Frequency Response 42 Hz – 20 kHz @ ±3 dB Materials Frame: One-piece die-cast aluminium; Enclosure: ABS reinforced; Grills: Kvadrat textile Connectivity Bluetooth® Qualcomm aptX™ HD audio; Wi-Fi Direct & networked (2.4 GHz); Wired optical or analog (3.5 mm mini-jack); USB-disk; Vifa®HOME, Vifa®LINK, Vifa®PLAY Driver Units Tweeter: 2 × 28 mm soft-dome drivers; Midrange: 2 × 80 mm aluminium-cone drivers; Woofer: 4 × 100 mm flat sandwich-cone drivers (force-balanced, backed by 4 passive radiators) Other Features Apple AirPlay & DLNA streaming; DSP signal processing; 6-channel high-performance power amplifier Get it at the link below: Vifa Stockholm 2.0 Bluetooth Soundbar, Nordic Design Soundbar, Smart APP Multi-Room System (Slate Black): $1156.99 (Sold and Shipped by Amazon US) This Amazon deal is US-specific and not available in other regions unless specified. If you don't like it or want to look at more options, check out the Amazon US deals page here. Get Prime (SNAP), Prime Video, Audible Plus or Kindle / Music Unlimited. Free for 30 days. As an Amazon Associate, we earn from qualifying purchases.
    • Explzh 9.81 by Razvan Serea Explzh is a free Windows archive manager for creating, extracting and managing archives. The program supports many different types of archives, including zip, 7z, rar, tar, ace, lzh, arj, cab, iso, img, msi, sfx and more. Apart from archive creation and extraction, you will also be able to verify compressed data for errors, initiate repair routines, split data into multiple items, and more. It additionally allows you to password protect your data and attach digital signatures to files. Key features of Explzh: Explorer-like GUI and operability. LHA, ZIP (ZIPX), JAR, CAB, RAR, TAR, TAR.XXX, 7z, ARJ, WIM, CHM, PE, HFS, NSIS Format Installer, ISO, InstallShield, MSI, and several other formats... Support for more archive formats by introducing the integrated archiver DLL. Self-extracting archive creation function that can create high-performance automatic installers. Digital signature addition function to created self-extracting archive. Office 2007 or later document compression / image optimization re-archiving function. Supports compression and decompression of Unicode file names. Supports compression and expansion exceeding 4GB. AES encryption function. You can create a robust secure ZIP encryption archive. Thumbnail function of image file. In-library file search function. . Equipped with archive file conversion function. File split function. The split file has a self-consolidation function, and can concatenate files larger than 4GB. (No need for batch file or connection software) UU (XX) Encode, Base64 decode function. FTP upload function Supports Windows 11 shell integration extended context menu. Explzh 9.81 changelog: Improved to send update notifications to the shell when making changes such as additional compression to existing zip and 7-zip files. This also updates the Explorer view of the open file in real time. (If the drop target feature is enabled, you can easily create an encrypted ZIP by dragging and dropping onto the ZIP icon while holding down the Ctrl key.) When the zip drop target setting is enabled, the "Compressed (zipped) Folder" item will be added to the "New" shell context menu if it does not already exist. Password manager bug fix: Fixed a bug that caused the app to crash when reading password.dat (password data) when changing authentication method. Updated to Visual Studio 2022 v.17.14.9. Download: Explzh 64-bit | Explzh 32-bit | ~6.0 MB (Freeware) Download: Explzh ARM64 | 5.9 MB View: Explzh Home Page | Screenshot | Themes Get alerted to all of our Software updates on Twitter at @NeowinSoftware
      Snake Doc earned a badge
      Sender88 earned a badge
      Daniel Pinto earned a badge
    • Explorer
      DougQuaid went up a rank
      Explorer
      138
      125
