RC Car with esp8266 and MicroPython - an approach with code
dear community
At the beginning of my story I have to say, that this was my first time to IOT topic - and to the ESP32 and 8266
I'm a complete beginner, but one thing I have is the desire to known new technologies.
A month ago my colleague make presentation about #esp8266 and I was impressed this small board. So I decided that I would like to known more about #esp8266 and similar stuff.
I use Micropython (http://micropython.org/download) it is a firmware for the #esp8266 boards. At the beginning i have to underestand how it works, but I have read allmost a ton of webpages and articles about it.
some ideas regarding the aims:
What is needed for the car: We need to meet some conditions with the RC-car.
We ......:
- have the car expect one command every second. If it does not receive one, it stops.
- We can of course use the connection type that fits our existing hardware or use-case best. Once we have decided that, the search for a good connection library starts.
well - if i want to go with some web-app or pc controlled thing, then i should choose TCP/IP / WIFI or bluetooth ( with ESP 32)
regarding the hardware:
firstly: I would say that i should not make use of an Uno and an esp-01 module. This makes life much more difficult.
i think that i should choose a Wemos Mini D1 or a nodeMCU board.  This will be smaller, cheaper and easier to use.
secondly perhaps i should choose a less old-fashioned motor driver than the 298. These will work well with 3.3V circuits,
be more efficient and maybe use fewer pins (which may be important when using the Wemos/nodeMCU). What do you think  about this idea.
thirdly i think that i have to go with MicroPython: - it is a pretty intersting approach to stick - working with ESP8266 or ESP32
btw regarding the use of MicroPython i have found an interesting approach here:
written by david golak:
https://hackaday.io/project/27444-remote-control-car-via-wifi
How to build RC Car with the esp8266.
see the code https://github.com/dgolak/esp8266/blob/master/main.py
import machine
import time
LED_PIN=15
led=machine.Pin(LED_PIN,machine.Pin.OUT)
led.off()
LIGHT_PIN_L=13
light_l=machine.Pin(LIGHT_PIN_L,machine.Pin.OUT)
light_l.off()
LIGHT_PIN_R=2
light_r=machine.Pin(LIGHT_PIN_R,machine.Pin.OUT)
light_r.off()
class engines:
    def __init__(self, machine):
        self.machine = machine
        self.left_first_pin = 0
        self.left_second_pin = 5
        self.right_first_pin = 14
        self.right_second_pin = 12
    def forward(self, duty=1000):
        self.stop()
        e1=machine.PWM(self.machine.Pin(self.left_first_pin),freq=100,duty=duty)
        e2=machine.PWM(self.machine.Pin(self.right_first_pin),freq=100,duty=duty)
    def backward(self, duty=1000):
        self.stop()
        e1=machine.PWM(self.machine.Pin(self.left_second_pin),freq=100,duty=duty)
        e2=machine.PWM(self.machine.Pin(self.right_second_pin),freq=100,duty=duty)
    def left_up(self):
        self.stop()
        e1=machine.PWM(self.machine.Pin(self.left_first_pin), freq=100, duty=400)
        e2=machine.PWM(machine.Pin(self.right_first_pin), freq=100, duty=1000)
    def right_up(self):
        self.stop()
        e1=machine.PWM(self.machine.Pin(self.left_first_pin),freq=100,duty=1000)
        e2=machine.PWM(self.machine.Pin(self.right_first_pin),freq=100,duty=400)
    def left_down(self):
        self.stop()
        e1=machine.PWM(self.machine.Pin(self.left_second_pin), freq=100, duty=400)
        e2=machine.PWM(machine.Pin(self.right_second_pin), freq=100, duty=1000)
    def right_down(self):
        self.stop()
        e1=machine.PWM(self.machine.Pin(self.left_second_pin),freq=100,duty=1000)
        e2=machine.PWM(self.machine.Pin(self.right_second_pin),freq=100,duty=400)
    def stop(self):
        machine.PWM(self.machine.Pin(self.left_first_pin),freq=0,duty=0)
        machine.PWM(self.machine.Pin(self.right_second_pin),freq=0,duty=0)
        machine.PWM(self.machine.Pin(self.left_second_pin),freq=0,duty=0)
        machine.PWM(self.machine.Pin(self.right_first_pin),freq=0,duty=0)
E=engines(machine)
try:
    import usocket as socket
except:
    import socket
CONTENT = b"""\
HTTP/1.0 200 OK
Hello #%d
CONTENT = b"""\
HTTP/1.0 200 OK
Content-Type: text/html\n\r
<html>
  <script src="https://ajax.googleapis.com/ajax/libs/jquery/2.1.4/jquery.min.js" type="text/javascript" charset="utf-8">
  </script>
<head>
<script type="text/javascript">
var DEVICE_URL = 'http://%s'
function iotAction(action){
    if(action=='change_led'){
        if(document.getElementById('led_value').value==1){
            action='led_off'
            document.getElementById('led_value').value=0
            document.getElementById('led_control').style.backgroundImage="url('https://raw.githubusercontent.com/dgolak/esp8266/master/images/alarm_off.jpg')"
        }else if(document.getElementById('led_value').value==0){
            action='led_on'
            document.getElementById('led_value').value=1
            document.getElementById('led_control').style.backgroundImage="url('https://raw.githubusercontent.com/dgolak/esp8266/master/images/alarm_on.jpg')"
        }else{
            action="led_on"
    if(action=='change_light'){
        if(document.getElementById('light_value').value==1){
            action='light_off'
            document.getElementById('light_value').value=0
            document.getElementById('light_control').style.backgroundImage="url('https://raw.githubusercontent.com/dgolak/esp8266/master/images/light_off.jpg')"
        }else if(document.getElementById('light_value').value==0){
            action='light_on'
            document.getElementById('light_value').value=1
            document.getElementById('light_control').style.backgroundImage="url('https://raw.githubusercontent.com/dgolak/esp8266/master/images/light_on.jpg')"
        }else{
            action="light_on"
    var requestURL = DEVICE_URL + "/?action="+action
    $.get (requestURL)
</script>
<style>
#container{
    width:800px;
    height:1300px;
    background-image:url("https://raw.githubusercontent.com/dgolak/esp8266/master/images/navi2.png");
    background-position:40px 110px;
    background-size:720px;
    background-repeat: no-repeat;
    -webkit-user-select: none;
    padding-top:100px;
button{
    background-color:transparent;
    border-color:transparent;
    border:0px solid red
</style>
</head>
<center>
<div id="container">
<table cellpadding="0" cellspacing="0">
<tr>
<td style="padding-left:130px;" colspan="3">
<button style="width:440px;height:150px" ontouchstart="iotAction('forward')" ontouchend="iotAction('stop')"/>
</td>
</tr>
<tr>
<td><button style="width:180px;height:190px" ontouchstart="iotAction('left_up')" ontouchend="iotAction('stop')"/></td>
<td rowspan="2"><button style="width:350px;height:370px" ontouchstart="iotAction('stop')" ontouchend="iotAction('stop')"/></td>
<td><button style="width:180px;height:190px" ontouchstart="iotAction('right_up')" ontouchend="iotAction('stop')"/></td>
</tr>
<tr>
<td><button style="width:180px;height:220px" ontouchstart="iotAction('left_down')" ontouchend="iotAction('stop')"/></td>
<td><button style="width:180px;height:220px" ontouchstart="iotAction('right_down')" ontouchend="iotAction('stop')"/></td>
</tr>
<tr>
<button style="width:440px;height:150px" ontouchstart="iotAction('backward')" ontouchend="iotAction('stop')"/>
</td>
</tr>
</table>
<br/><br/>
<table>
<tr>
<td>
<input type="hidden" id="light_value" value="0"/>
<button id="light_control" style="width:200px;height:200px;background-image:url('https://raw.githubusercontent.com/dgolak/esp8266/master/images/light_off.jpg');background-size:200pxontouchstart="iotAction('change_light')"></button>
</td>
<td>
<input type="hidden" id="led_value" value="0"/>
<button id="led_control" style="margin-left:20px;width:200px;height:200px;background-image:url('https://raw.githubusercontent.com/dgolak/esp8266/master/images/%s');background-size:200pxontouchstart="iotAction('change_led')"></button>
</td>
</tr>
</table>
</div>
</center>
</html>
def main(E,micropython_optimize=False):
    s = socket.socket()
    ai = socket.getaddrinfo("172.20.10.10", 80)
    addr = ai[0][-1]
    s.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
    s.bind(addr)
    s.listen(5)
    while True:
        res = s.accept()
        client_sock=res[0]
        if not micropython_optimize:
            client_stream = client_sock.makefile("rwb")
        else:
        req = client_stream.readline()
        get = req.split()[1].decode('utf-8')
        if get == '/?action=forward':
            E.forward()
        elif get == '/?action=left_up':
            E.left_up()
        elif get == '/?action=right_up':
            E.right_up()
        elif get == '/?action=left_down':
            E.left_down()
        elif get == '/?action=right_down':
            E.right_down()
        elif get == '/?action=backward':
            E.backward()
        elif get == '/?action=stop':
            E.stop()
        elif get == '/?action=led_on':
            led.on()
        elif get == '/?action=led_off':
            led.off()
        elif get == '/?action=light_on':
            light_l.on()
            light_r.on()
        elif get == '/?action=light_off':
            light_l.off()
            light_r.off()
        else:
            pass
        while True:
            h = client_stream.readline()
            if h == b"" or h == b"\r\n":
                break
        if led.value() == 1:
            led_icon="alarm_on.jpg"
        else:
            led_icon = "alarm_off.jpg"
        client_stream.write(CONTENT % (wlan.ifconfig()[0],led_icon))
        client_stream.close()
            client_sock.close()
main(E)
see  https://github.com/dgolak/esp8266/blob/master/main.py
well i guess that this is a straingthforward approach...
cf:  david golak:
btw: my car has got a option of a steering axle - in other words - i have a slightly different car  - than David has.
But that i think does not make a big difference.. I have to change the code at some places to fit.
i will have a closer look at this.
regards
2 answers to this question
in my opinion, as far as the RC car system goes, you should just get an off the shelf toy RC car, then remove the original radio system, but leave the steering servo and onboard motor controller intact... this way it is probably cheaper, and saves you the headache of building the mechanics like the drivetrain, the battery compartment, where all the components are mounted, etc etc, and you have an already working steering axle system
there is a possibility that the motor controller is intergrated into the receiver circuitry in the case of the nastily cheap toys, in that case you will have to buy separate speed controller from a hobby shop, it shouldn't cost too much money
then, you interface the esp8266 with the servo and the motor controller using this https://www.instructables.com/id/Interfacing-Servo-Motor-With-NodeMCU/ ... the motor controller uses the same signals as the servo, you connect the servo to one of the outputs and the motor controller to a different output, and change the code accordingly
Edited by carmatic
i see in the code that there is a reference to PWM signals being output from pin 13 and pin 2, if you want to control a steering servo and a motor speed controller (they use the same signals), read this https://learn.sparkfun.com/tutorials/hobby-servo-tutorial
    • They are shifting into AI now. Don't you see?
    • Exactly. No need to pay to rent a license. I'd rather own it.
    • Weekend PC Game Deals: Automation fests, Civilization for free, charity specials, and more by Pulasthi Ariyasinghe Weekend PC Game Deals is where the hottest gaming deals from all over the internet are gathered into one place every week for your consumption. So kick back, relax, and hold on to your wallets. The Epic Games Store unlocked a big strategy game giveaway earlier this week: Civilization VI: Platinum Edition. Coming in from Firaxis Games, the turn-based 4X experience has you starting world-conquering campaigns to explore, expand, exploit, and exterminate everything in your empire's reach. PvP and co-op multiplayer are also options if the various forms of AI prove to be too easy or even too troublesome. The Sid Meier’s Civilization VI: Platinum Edition giveaway is live until July 24, and it comes with two massive expansions as well as six DLC packs with extra scenarios, leaders, and more. Next week, tower defense title Legion TD 2 will become the latest freebie on the Epic Games Store. The Humble Store brought a new bundle for action game fans this weekend, and it's all about the Devil May Cry franchise. The Devil Trigger Collection begins with DmC: Devil May Cry and Devil May Cry HD Collection for $10. If you want to complete the bundle, it will set you back $20, which gets you Devil May Cry 4 Special Edition as well as the most recent entry, Devil May Cry 5, as well as its Vergil DLC. This bundle has two weeks left on its counter before it goes away. Big Deals Most publishers are returning to their usual weekend specials after the massive summer sales, so there are plenty of discounts to go around. There's even a special Make a Wish charity sale running on Steam with some discounted viral hits. With all those and more, here's our hand-picked big deals list for the weekend: Satisfactory – $27.99 on Steam Captain of Industry – $24.49 on Steam No Man's Sky – $23.99 on Steam Persona 5 Royal – $23.99 on Steam No More Room in Hell 2 – $22.49 on Steam FOUNDRY – $20.99 on Steam Banishers: Ghosts of New Eden – $19.99 on Steam SULFUR – $19.99 on Steam Assassin's Creed Mirage – $19.99 on Steam Alan Wake 2 – $19.99 on Epic Store Grand Theft Auto V Enhanced – $19.79 on Steam Norland – $19.49 on Steam Stray – $17.99 on Steam V Rising – $17.49 on Steam Dyson Sphere Program – $15.99 on Steam The Outlast Trials – $15.99 on Steam Warhammer 40,000: Darktide – $15.99 on Steam The Outlast Trials – $15.99 on Steam Red Dead Redemption 2 – $14.99 on Steam Turing Complete – $13.99 on Steam Eden Crafters – $13.99 on Steam Core Keeper – $13.99 on Steam Thank Goodness You're Here! – $12.99 on Steam Opus Magnum – $9.99 on Steam Autonauts – $9.99 on Steam EXAPUNKS – $9.99 on Steam DRAGON BALL XENOVERSE 2 – $9.99 on Steam Superliminal – $9.99 on Steam Heaven's Vault – $9.99 on Steam RAILGRADE – $9.89 on Steam Goat Simulator 3 – $9.89 on Steam Tchia – $9.89 on Steam ACE COMBAT 7: SKIES UNKNOWN – $9.59 on Steam PAYDAY 3 – $8.99 on Steam Assassin's Creed Origins – $8.99 on Steam Viewfinder – $8.74 on Steam Escape Academy – $7.99 on Steam Pit People – $7.99 on Steam Skull and Bones – $7.99 on Steam Immortals Fenyx Rising – $7.99 on Steam Imperator: Rome – $7.59 on Steam SHENZHEN I/O – $7.49 on Steam Tom Clancy’s The Division 2 – $7.49 on Steam Bassmaster Fishing – $7.49 on Steam Let's Build a Zoo – $6.99 on Steam The Forgotten City – $6.24 on Steam Control Ultimate Edition – $5.99 on Steam Bramble: The Mountain King – $5.99 on Steam Assassin’s Creed Rogue – $5.99 on Steam RoboCop: Rogue City – $4.99 on Steam Kingdom Two Crowns – $4.99 on Steam Scott Pilgrim vs. The World: The Game – $4.94 on Steam Castle Crashers – $4.49 on Steam BattleBlock Theater – $4.49 on Steam TOEM: A Photo Adventure – $3.99 on Steam Supraland – $3.99 on Steam Vampire Survivors – $3.99 on Steam Darkwood – $3.74 on Steam Valiant Hearts: The Great War – $3.74 on Steam TIS-100 – $3.49 on Steam PAYDAY 2 – $3.29 on Steam Cake Bash – $2.99 on Steam Ragnarock – $1.99 on Steam Alan Wake – $1.49 on Steam Civilization VI Platinum Edition – $0 on Epic Store DRM-free Specials Lastly, here are some highlights from the DRM-free discounts available on the GOG store this weekend: Age of Wonders 4 - $29.99 on GOG Pathfinder: Wrath of the Righteous - Game of the Year Edition - $19.99 on GOG Tomb Raider IV-VI Remastered - $19.49 on GOG The Thaumaturge - $19.24 on GOG Chained Echoes - $13.74 on GOG Tyranny - Gold Edition - $12.49 on GOG Tomb Raider I-III Remastered Starring Lara Croft - $11.99 on GOG Baldur's Gate: Enhanced Edition - $9.99 on GOG Baldur's Gate II: Enhanced Edition - $9.99 on GOG Neverwinter Nights: Enhanced Edition - $9.99 on GOG Old World - $9.99 on GOG Icewind Dale: Enhanced Edition - $9.99 on GOG Neverwinter Nights: Doom of Icewind Dale - $7.99 on GOG Kingdom Come: Deliverance - $5.99 on GOG Might and Magic 6-pack Limited Edition - $4.99 on GOG Heroes of Might and Magic 3: Complete - $4.99 on GOG Blood Omen: Legacy of Kain - $3.49 on GOG Might and Magic 8: Day of the Destroyer™ - $2.99 on GOG Worms Armageddon - $2.99 on GOG ATOM RPG: Post-apocalyptic indie game - $2.99 on GOG Keep in mind that availability and pricing for some deals could vary depending on the region. That's it for our pick of this weekend's PC game deals, and hopefully, some of you have enough self-restraint not to keep adding to your ever-growing backlogs. As always, there are an enormous number of other deals ready and waiting all over the interwebs, as well as on services you may already subscribe to if you comb through them, so keep your eyes open for those, and have a great weekend.
    • Wild that this was even allowed from the jump
      161
      138
