I have setup ADFS using Windows Server 2016. I have everything working and working through Nginx. However, I have one issue I can't see to fix.
connect.mydomainname.com /adfs is an external DNS name that points to an internal hostname of the ADFS server (EL-ADFS-01.ad.mydomainname.com)
when I login to connect.mydomainname.com/adfs I login with a vaild username and password, it redirects me to EL-ADFS-01.ad.mydomainname.com. I have it working by having an external DNS entry to point to the same firewall as the connect.mydomainname.com
If I use a bad user/pass, I don't get a redirect, just that it's a bad user/pass.
I've messed around with the nginx settings some and I'm not sure the issue is with nginx since it seems to only happen for  successful logins.
Any ideas?
https://www.neowin.net/forum/topic/1382536-adfs-redirection-help/
  • 2 weeks later...
  On 20/05/2019 at 15:13, Dented said:
You can't use CName records for. AD FS. It needs to be an A-record pointing to the internal ip.
Expand
Sorry about the short reply, was on the phone on a bus.
If you give me a bit more detail on your setup I think I can help you.
How many ADFS hosts do you have?
Are you using nginx for load balancing internal connections between multiple hosts, as a reverse proxy for publishing AD FS externally, or both?
Do you have the mydomain.com zone internally as well as externally?
Does nginx do DNS-lookups externally or internally?
connect.mydomain.com needs to be an A-Record both internally and externally. It cannot be a CName(alias). If nginx is used as a load balancer, the AD FS nodes must be configured with IP in nginx, not host name. If nginx is used as a reverse proxy, it must connect to the internal AD FS farm using FQDN of connect.mydomain.com, which must be an A-Record or a local host record on the nginx server.
That said, I know nothing about nginx, but I am fairly familiar with AD FS.
Thank you everyone for your help.
I actually had ADFS setup incorrectly. The domain that I was using was the internal dns name and not the dns name of the proxy server. Once I changed this in the ADFS Console, everything started working. Then I setup Duo for 2FA and everything is working great.
Thanks!
