How to call an external command in Python: with os.system or with the subprocess-module!?
hello dear experts on neowin,
Imagine i am on Windows and type at the command prompt from within a Python script? can i do this with  - the subprocess module in the standard library:
import subprocess
subprocess.run(["ls", "-l"])
The official Python-documentation recommends the subprocess module over the alternative os.system():
my question is: which method id more powerful has more advantages - what are the downsides?
a big big advantage from os.system: it passes the command and arguments to our system's shell.
 os.system("some_command with args"):
This is very cool - because we can perform multiple commands at the same time;  in this manner and set up pipes and input/output redirection.
The advantage of subprocess vs. system is told to be
- more flexible : since we can get the stdout, stderr, the "real" status code, .
- the subprocess module provides more powerful facilities for spawning new processes and retrieving their results;
- and lots of other things more...
to point out one of the advantages of os.system:
os.system("some_command with args") passes the command and arguments to our system's shell.  a very very cool features: we are able to perform multiple commands at the same time.  and we can set up pipes and input/output redirection.
os.system("some_command < input_file | another_command > output_file")
Question: which approach do  you use - how do you call an external command in Python?
love to hear from you
0 answers to this question
There have been no answers to this question yet
