Hi! So I noticed while playing the new Star Wars game Jedi: Fallen Order, my cpu temperature goes all the way to 100°C.
My PC specs are: i5 4690k (oc to 4.0ghz) stock cooler
MB: Gigabyte ga-z97x-gaming5
1060 6gb
2x8gb ram (1600)
ssd
Windows 7
So a few years ago I OC my cpu to 4Ghz. Worked just fine, no crashes or anything. I clean the dust inside, change termal paste, but it's still too high, goes to 90°C.
I have Antec case, which has two ventilators on top and one in back.
I also put all bios settings back to default, and after running Prime95 for 15 mins, I got these temps:
Is this suppose to be normal? Any advice what could I do?
https://www.neowin.net/forum/topic/1389498-cpu-temp-too-high/
  On 24/11/2019 at 18:13, Matthew S. said:
For AIO's any one of the ones listed here
Just look for anything that'll fit LGA1150 sockets, also be aware of your space available in your case.
Expand
Most AIOs of the latest gen are universal...
Tj. Max is when the CPU will get throttled, it's not saying your Tj temp is 100°C. Yes, your core temps are hella high, but you can partly fix that by setting your clock speed back to stock (take off the clock). Then once you get a new HSF (I assume you can find something by Noctua on Amazon Slovenia), get some decent paste on and put the clock back up.
ypu shouldnt need to overclock that thing anyway as the boost setting will scale it to 4ghz anyways, and the stock coolers are just fine, im using one on my 4790k i7 and mine usually sits on about 80c at 4ghz when gaming, maybe check your thermal paste and reseat the cooler
oh and those temps are perfectly fine to be honest 75ish at 4 core 100% load is normal
I agree with the others.. look at a new cooler.  Watercooled is likely overkill and not worth the money to switch over..
Also, double check that everything is seated properly and if it is, I'd double check you put enough thermal paste on.
I had a PC that had a similar issue and it ended up being one of the cooler pegs had come loose while I was tightening the other 3.
  On 25/11/2019 at 12:47, yoco said:
Any other good alternatives? Literally every store I looked at is out of stock!
Expand
Just google images of "120mm air cooler" and choose whichever one you like the most. Although make sure that your case is big enough to accommodate one, so do check the dimensions of the cooler.
For a tower Cooler - need clearance for height of  cooler
cheap - Cooler Master Hyper 212 Evo
mid range - ARCTIC Freezer 34
high end - be quiet! Dark Rock PRO
AIO Water coolers  - also need space to mount radiator and fans
cheap - Cooler Master MasterLiquid Lite 240
mid range - CORSAIR Hydro Series H100x
high end - ROG STRIX LC 360 RGB
Register a new account
Sign in
