write stdout using write_csv() ...
dear Fellow Coder on Neowin
im using bash to pipe the gathered data through an Rscript like so:
cat random.csv | Rscript test.R arg >| delete.csv
My aim is to use the R package readr to both read stdin and write stdout. what is aimed:  I found the answer to stdin here.
test.R
#!/usr/bin/Rscript
suppressMessages(library(readr))
args  <- commandArgs(trailingOnly = TRUE)
df.in <- read_csv(file("stdin"))
write_csv(df.in, path = stdout())
My investigations gave back the foolowing:
There is a format_csv function for that in readr. Use this instead of write_csv:
cat(format_csv(df.in))
we also can use write.table:
write.table(x, file = "foo.csv", sep = ",", col.names = NA,
        qmethod = "double")
i found the following interesting help page: https://stat.ethz.ch/R-manual/R-devel/library/utils/html/write.table.html
import requests
from bs4 import BeautifulSoup
import pandas as pd
def Main(urls):
    with requests.Session() as req:
        allin = []
        for url in urls:
            r = req.get(url)
            soup = BeautifulSoup(r.content, 'html.parser')
            target = soup.find(
                "dl", class_="c-description-list c-description-list--striped")
            names = [item.text for item in target.findAll("dt")]
            names.append("url")
            data = [item.get_text(strip=True) for item in target.findAll("dd")]
            data.append(url)
            allin.append(data)
        df = pd.DataFrame(allin, columns=names)
        df.to_csv("data.csv", index=False, encoding="utf-8")
urls = ['https://www2.daad.de/deutschland/studienangebote/international-programmes/en/detail/4722/',
        'https://www2.daad.de/deutschland/studienangebote/international-programmes/en/detail/6318/']
Main(urls)
the question is. i want to write the results of the parser script to stdout . - i do not want to write it into the data-file.
https://www.neowin.net/forum/topic/1393718-write-stdout-using-write_csv%C2%A0/
1 answer to this question
According to this:
https://pandas.pydata.org/pandas-docs/stable/reference/api/pandas.DataFrame.to_csv.html
"to_csv()" returns a string if no file path/object is specified, so you should be able to print the result to stdout.
Register a new account
Sign in
    • Amazon Deal: This Vifa Stockholm 2.0 is one of the best sounding bluetooth speakers by Sayan Sen A few days back we covered some great JBL bluetooth speaker deals across several of its popular models. The discounts are still live and you can check them out in this dedicated piece. Meanwhile for those who prefer more powerful home cinema sound systems, Nakamichi and Samsung are offering the Dragon and Shockwafe models, and the Q-series models, respectively, at their best ever prices. However, if you are someone who is looking for a bit of both, the portability of a bluetooth speaker and the fidelity of a good sounding hi-fi system then the Vifa Stockholm 2.0 Bluetooth Soundbar is something you should look at as it's currently a nice deal (purchase link under the specs table below). While you are not getting a subwoofer with the Vifa Stockholm as it is a 2.0 system, Vifa promises lows down to 42 Hz at +3dB and that should be pretty good for a device lacking a dedicated bass unit; it does pack passive radiators to help with the bass. The Stockholm 2.0 is praised for its sound quality (SQ) and one of the reasons behind it is becasue it has three-way drivers. The technical specifications of the Vifa Stockholm 2.0 Bluetooth Soundbar are given below: Specification Frequency Response 42 Hz – 20 kHz @ ±3 dB Materials Frame: One-piece die-cast aluminium; Enclosure: ABS reinforced; Grills: Kvadrat textile Connectivity Bluetooth® Qualcomm aptX™ HD audio; Wi-Fi Direct & networked (2.4 GHz); Wired optical or analog (3.5 mm mini-jack); USB-disk; Vifa®HOME, Vifa®LINK, Vifa®PLAY Driver Units Tweeter: 2 × 28 mm soft-dome drivers; Midrange: 2 × 80 mm aluminium-cone drivers; Woofer: 4 × 100 mm flat sandwich-cone drivers (force-balanced, backed by 4 passive radiators) Other Features Apple AirPlay & DLNA streaming; DSP signal processing; 6-channel high-performance power amplifier Get it at the link below: Vifa Stockholm 2.0 Bluetooth Soundbar, Nordic Design Soundbar, Smart APP Multi-Room System (Slate Black): $1156.99 (Sold and Shipped by Amazon US) This Amazon deal is US-specific and not available in other regions unless specified. If you don't like it or want to look at more options, check out the Amazon US deals page here. Get Prime (SNAP), Prime Video, Audible Plus or Kindle / Music Unlimited. Free for 30 days. As an Amazon Associate, we earn from qualifying purchases.
    • Explzh 9.81 by Razvan Serea Explzh is a free Windows archive manager for creating, extracting and managing archives. The program supports many different types of archives, including zip, 7z, rar, tar, ace, lzh, arj, cab, iso, img, msi, sfx and more. Apart from archive creation and extraction, you will also be able to verify compressed data for errors, initiate repair routines, split data into multiple items, and more. It additionally allows you to password protect your data and attach digital signatures to files. Key features of Explzh: Explorer-like GUI and operability. LHA, ZIP (ZIPX), JAR, CAB, RAR, TAR, TAR.XXX, 7z, ARJ, WIM, CHM, PE, HFS, NSIS Format Installer, ISO, InstallShield, MSI, and several other formats... Support for more archive formats by introducing the integrated archiver DLL. Self-extracting archive creation function that can create high-performance automatic installers. Digital signature addition function to created self-extracting archive. Office 2007 or later document compression / image optimization re-archiving function. Supports compression and decompression of Unicode file names. Supports compression and expansion exceeding 4GB. AES encryption function. You can create a robust secure ZIP encryption archive. Thumbnail function of image file. In-library file search function. . Equipped with archive file conversion function. File split function. The split file has a self-consolidation function, and can concatenate files larger than 4GB. (No need for batch file or connection software) UU (XX) Encode, Base64 decode function. FTP upload function Supports Windows 11 shell integration extended context menu. Explzh 9.81 changelog: Improved to send update notifications to the shell when making changes such as additional compression to existing zip and 7-zip files. This also updates the Explorer view of the open file in real time. (If the drop target feature is enabled, you can easily create an encrypted ZIP by dragging and dropping onto the ZIP icon while holding down the Ctrl key.) When the zip drop target setting is enabled, the "Compressed (zipped) Folder" item will be added to the "New" shell context menu if it does not already exist. Password manager bug fix: Fixed a bug that caused the app to crash when reading password.dat (password data) when changing authentication method. Updated to Visual Studio 2022 v.17.14.9. Download: Explzh 64-bit | Explzh 32-bit | ~6.0 MB (Freeware) Download: Explzh ARM64 | 5.9 MB View: Explzh Home Page | Screenshot | Themes Get alerted to all of our Software updates on Twitter at @NeowinSoftware
    • Have to get that indoctrination in early I guess
    • The reason why I'm using as much portable software as possible.
      Sender88 earned a badge
      Daniel Pinto earned a badge
    • Explorer
      DougQuaid went up a rank
      Explorer
      MIghty Haul earned a badge
      138
      126
