Need a open source sound system software.
Hello. I am planning to add sound speaker in every room of the house. I am just asking if there is a sound system that I can install in Linux and manages the speakers for me. Other than buying a ready make solutions.
Also, it would be better if it supports docker also.
Thanks,
What sort of speakers are you planning on putting in exactly..  Something like sonos sort of speakers, Bluetooth, just old school wired speakers connected to some receiver or avr?
PulseAudio is usually included in most disto's. It does a great amount of functionality. It did that with my 2x headsets (USB and 3.5mm jack) and my bluetooth speakers.
Register a new account
Sign in
    • Glow 25.08 by Razvan Serea Glow provides detailed reporting on every hardware component in your computer, saving you valuable time typically spent searching for CPU, motherboard, RAM, graphics card, and other stats. With Glow, all the information is conveniently presented in one clean interface, allowing you to easily access and review the comprehensive hardware details of your system. Glow provides detailed information on various system aspects, including OS, motherboard, processor, memory, graphics card, storage, network, battery, drivers, and services. The well-organized format ensures easy access to the required information. You can export all the gathered data to a plain text file, facilitating sharing with others for troubleshooting purposes. No installation needed. Just decompress the archive, launch the executable, and access computer-related information. Glow runs on Windows 11 and Windows 10 64-bit versions. Glow 25.08 release notes: What's new Glow's render engine has been improved. The program now supports high-resolution displays even on multi-monitor setups and monitors with varying DPI levels. It delivers sharp and clear visuals on 8K and higher DPI screens. The TSImageRenderer algorithm has been integrated into Glow. All visual icons in the interface are now automatically resized in a DPI-aware manner, ensuring high-resolution display quality. We know that Glow's Installed Drivers and Installed Services sections load slowly. That's why the loading algorithms have been reprogrammed into a parallel structure. Now it loads with up to 95% speed increase compared to the processor core. Glow's monitor testing tools have been reprogrammed. The Dead Pixel Test and Dynamic Color Range Test now function with improved accuracy. The Screen Overlay Tool has been redesigned, featuring theme sensitivity and new functions such as a close button. The startup engine for all Glow tools has been redeveloped, allowing for more efficient and effective management of the tools. The search engine's clear button in the "Installed Drivers", "Installed Services" and "Installed Applications" sections has been refreshed with a DPI-aware design for enhanced visibility. Icons have been added to the BIOS Update, Battery Report Generation, and Export buttons. Icons have been added to all buttons across Glow's tools. The Tab key functionality in Glow's interface has been improved, enabling more precise and stable navigation between elements. Glow's logo has been updated with a new design, offering a more elegant and modern appearance. Glow's primary colors have been redesigned within the Adobe RGB Color Space, giving the interface a more contemporary look. The About section has been reprogrammed. All social media buttons now feature icons, and the close button is DPI-aware and more prominent. Fixed Bugs Fixed an issue causing control buttons to overlap and shift position at high DPI settings. Resolved a DPI-related issue where checkmarks in the top menu distorted visually at high DPI values. Fixed a parallel processing error that caused the program to crash after clicking and closing information text in any monitor test tool. Corrected a bug in the Dynamic Color Range Tool that caused white space to appear on the right and bottom when resizing. Fixed calculation errors affecting the color scale and ratios in the Dynamic Color Range Tool. Resolved a layering issue that sometimes caused message boxes to appear behind the program window. Changes The backend code structure of Glow has been improved to a modular architecture, ensuring full compatibility and easier integration with other Türkay Software products. Tools have been moved back to the top menu. Some interface icons have been replaced to provide better visual clarity. A YouTube link has been added to the About section. Note: Always unzip the program before using it. Otherwise you may get an error. Download: Glow 25.08 | 3.1 MB (Open Source) View: Glow Homepage | Screenshot Get alerted to all of our Software updates on Twitter at @NeowinSoftware
    • Vivaldi 7.5.3735.56 by Razvan Serea Vivaldi is a cross-platform web browser built for – and with – the web. A browser based on the Blink engine (same in Chrome and Chromium) that is fast, but also a browser that is rich in functionality, highly flexible and puts the user first. A browser that is made for you. Vivaldi is produced with love by a founding team of browser pioneers, including former CEO Jon Stephenson von Tetzchner, who co-founded and led Opera Software. Vivaldi’s interface is very customizable. Vivaldi combines simplicity and fashion to create a basic, highly customizable interface that provides everything a internet user could need. The browser allows users to customize the appearance of UI elements such as background color, overall theme, address bar and tab positioning, and start pages. Vivaldi features the ability to "stack" and "tile" tabs, annotate web pages, add notes to bookmarks and much more. Vivaldi 7.5.3735.56 changelog: [Chromium] Update to 138.0.7204.173 Download: Vivaldi 64-bit | 123.0 MB (Freeware) Download: Vivaldi 32-bit | ARM64 View: Vivaldi Home Page | Screenshot | Release Notes Get alerted to all of our Software updates on Twitter at @NeowinSoftware
    • Floorp 11.29.0 by Razvan Serea Floorp is a cutting-edge web browser that combines the trusted foundation of Mozilla's Firefox with a unique Japanese perspective, offering users an exceptional online experience. This open-source browser prioritizes privacy, customization, and security. Floorp is transparent, with no user tracking or data sharing, and it's completely open source. With a strict no-tracking policy and full transparency, your personal information remains private. As an open-source project, Floorp not only shares its source code but also its build environment, inviting users to contribute and build their unique versions. The regular updates, based on Firefox ESR, ensure that you always have the latest features and security enhancements. Get to the point with Floorp Lightning's minimalism With a keen eye on user preferences, Floorp is gearing up to launch "Floorp Lightning," a streamlined and performance-focused browser, harkening back to the fundamentals of web browsing. This browser has undergone a meticulous transformation, shedding more than 80% of the features that characterized its predecessor. What remains are only the high-demand functionalities within the Floorp ecosystem. The result is a sleek, lean, and swift web browser optimized for maximum efficiency. In the ever-accelerating digital world, "Floorp Lightning" is poised to offer users a refreshingly nimble and responsive browsing experience, set to debut in beta mode this November. Floorp key features: Strong Tracking Protection: Floorp offers robust tracking protection, safeguarding users from malicious tracking and fingerprinting on the web. Flexible Layout: Customize Floorp's layout to your heart's content, including moving the tab bar, hiding the title bar, and more for a personalized browsing experience. Switchable Design: Choose from five distinct designs for the Floorp interface, and even switch between OS-specific designs for a unique look Regular Updates: Based on Firefox ESR, Floorp receives updates every four weeks, ensuring up-to-date security even before Firefox's releases. No User Tracking: Floorp prioritizes user privacy by abstaining from collecting personal information, tracking users, or selling user data, with no affiliations with advertising companies. Completely Open Source: The full source code for Floorp is open to the public, allowing transparency and enabling anyone to explore and build their own version. Dual Sidebar: Floorp features a versatile built-in sidebar for webpanels and browsing tools, making it perfect for multitasking and quick access to bookmarks, history, and websites. Flexible Toolbar & Tab Bar: Customize your browser with Tree Style Tabs, vertical tabs, and bookmark bar modifications, catering to both beginners and experts in customization. User-Centric Web Experience: Floorp prioritizes user privacy and collaboratively blocks harmful trackers. Floorp 11.29.0 changelog: Security fixes Download: Floorp 64-bit | 85.2 MB (Open Source) Links: Floorp Website | Github Website | Screenshot Get alerted to all of our Software updates on Twitter at @NeowinSoftware
    • "ethical", what an interesting term. Subjectively objective but objectively subjective. I argue there are very few "ethics" in copyright. Hell, I see very few applications of true ethics in anything. I see a great deal of unethical actions being done under the guise of ethics however. How unethical... I greatly prefer open source LLMs. Copyright ethics are mickey mouse deep.
    • Collaborator
      fernan99 earned a badge
      Collaborator
    • Collaborator
      MikeK13 earned a badge
      Collaborator
      Alexander 001 earned a badge
      Antonio Barboza earned a badge
      139
      128
