Need help coming up with an efficient algorithm pseudocode.
I need help coming up with an efficient algorithm for the below.  The automation software i am using has a very limited syntax, can use for loops and if else statements and all the math functions.
I have several variables.
Boolean Variable S = Start Step Sequence - True/False
Integer Variable R = Total Number of Recipes - Constant of 50
Integer Variable X = Number of Recipe Steps - Can be 1 to (Variable R)
Integer Variable Y = Starting Recipe Step - Can be 1 to (Variable R)
Integer Variable Z = Ending Recipe Step - Can be 1 to (Variable R)
Integer Variable C = Current Recipe Step - Can be 1 to (Variable R)
Integer Variable T = Time Duration - Constant 60 seconds
Boolean Variable D = Steps Done - True/False
So I am working on a problem where the end user can Change Variable X and Y.
At minimum i need an algorithm that can look at the Number of steps (Variable X) and then take the input of the starting Step (Variable Y) and then Calculate the Ending Step (Variable Z). If the steps cause Variable Z to go past 50 (Variable R) then is starts back at 1 and increments the value up accordingly.
Once Start Step Sequence (Variable S) is set to True then the algorithm will need to start at Variable Y and assign this to the Current Recipe Step (Variable C) then every Time Duration (Variable T) it needs to increment Variable C up by 1 to the next step. If the Ending Step (Variable Z) is such that it is less than the starting step (Variable Y) due to the to the number of steps causing the value to roll over then the same thing would need to happen with variable C and once at a value of 50 (Variable R) and more increments are required it would roll over to 1 and keep incrementing up until the number of steps is completed meaning Variable C is equal to Variable Z and the duration of the final step has expired. THen once the final step duration has completed flag Steps Done (Variable D) to True and set Variable S to false.
1 answer to this question
Register a new account
Sign in
    • MIT's stunning 'bubble wrap' device squeezes water out from thin air even in deserts by Sayan Sen Image by Matteo Roman via Pexels Massachusetts Institute of Technology (MIT) engineers have built a new kind of device that can pull clean drinking water straight out of the air—no electricity needed. It’s designed for areas where water is scarce and traditional sources like rivers or lakes aren’t reliable. Right now, more than 2.2 billion people globally don’t have access to safe drinking water. In the United States alone, 46 million face water insecurity, with either no running water or water that’s not safe to drink. This new device, called an Atmospheric Water Harvesting Window (AWHW), uses a unique hydrogel panel that looks like black bubble wrap. These dome-shaped bubbles soak up water vapor from the air, especially at night when humidity is higher. During the day, sunlight makes the vapor inside evaporate. That vapor then condenses on a glass surface and drips down through a tube, turning into drinkable water. The AWHW doesn’t rely on power sources like batteries or solar panels. It’s completely passive, meaning it works on its own. The team tested a meter-sized panel in Death Valley, California, one of the driest places in North America, and got between 57.0 and 161.5 milliliters of water per day even with humidity as low as 21 percent. That’s more than what other similar passive devices have managed. “We have built a meter-scale device that we hope to deploy in resource-limited regions, where even a solar cell is not very accessible,” said Xuanhe Zhao, a professor at MIT. “It’s a test of feasibility in scaling up this water harvesting technology. Now people can build it even larger, or make it into parallel panels, to supply drinking water to people and achieve real impact.” Another cool part of the design is how they kept the water safe to drink. Usually, these kinds of hydrogels use salts like lithium chloride to absorb more vapor but that can lead to salt leaking into the water, which isn’t ideal. To solve this, MIT’s team mixed in glycerol, a compound that helps keep salt locked inside the gel. In testing, the lithium ion concentration in the harvested water stayed below 0.06 ppm (parts per million), which is way below the safe limit. The hydrogel domes also give the material more surface area, letting it collect more vapor. The outer glass panel is coated with a special polymer film that helps cool the glass, making it easier for vapor to condense. “This is just a proof-of-concept design, and there are a lot of things we can optimize,” said lead author Chang Liu, now a professor at the National University of Singapore. “For instance, we could have a multipanel design. And we’re working on a next generation of the material to further improve its intrinsic properties.” Published in Nature Water, the study says the AWHW could last at least a year and shows promise for making safe, sustainable water in places with harsh climates. The researchers believe an array of vertical panels could one day supply water to individual households, especially in remote or off-grid locations. Source: MIT News, Nature This article was generated with some help from AI and reviewed by an editor. Under Section 107 of the Copyright Act 1976, this material is used for the purpose of news reporting. Fair use is a use permitted by copyright statute that might otherwise be infringing.
    • Clear Linux is open source, indeed, so its source code is available for anyone. They're just shutting down its support from them, they're not forbidding anyone else from taking over.
    • Linux Mint is also my favorite distro, but I fear what will happen with it if Clem were to disappear tomorrow, to be honest.
    • Yeah, I totally get your point, which is possible it could happen. I just hope there is a few people around him who are similar to where if they took over things would run pretty much the same. if not, then yeah, it could start to decline rapidly etc. but I figure something that's been around for a longer period of time with a decent backing, and probably more users than most Linux distro's (which I would 'imagine' Mint is one of the more used Linux desktop distro's by volume of people who use it), is less likely to just disappear. but like you said, nothing is guaranteed. but I do think you are probably right in that Clem is probably the core of what keeps Mint, Mint. I like how it tends to stay pretty much the same with some slight tweaks here and there (but is largely the same) instead of that crap some people go for with change for the sake of change trying to create a overly fancy interface and other unnecessary stuff etc. I also feel Mint keeps a nice balance of things out-of-the-box where it's not too bloated, nor too striped down. p.s. but I see Mint as a better Ubuntu basically. but I get your point like if it was more of a really serious choice of needing a 'safe bet' to use long term, then yeah something like official Ubuntu would be one of the better choices for sure given what you said with it being backed by an actual company which makes it a safer bet than Mint which is smaller and 'could' potentially be more fragile.
    • It’s in development so hopefully it’s improved upon before release.
      leoniDAM earned a badge
      Ian_ earned a badge
      Ian_ earned a badge
      MacDaddyAz earned a badge
    • Explorer
      cekicen went up a rank
      Explorer
      146
      121
