Need help with the ForFiles command
I have the command in a bat file like this:
ForFiles /p "H:\CCTV\video" /s /d -30 /c "cmd /c del /q @file"
To clear out any file greater than 30 days old, this seems to work somewhat, but there are 4 sub-folders with in the CCTV folder, and it appears that it seems to be clearing 3 or 4 but it doesn't seem to be doing anything in the 4th, the command is still running, but does not appear to be doing anything else. Is that syntax correct for clearing all folders?
https://www.neowin.net/forum/topic/1420226-need-help-with-the-forfiles-command/
  On 01/08/2022 at 22:07, Biscuits Brown said:
Think you need a /s in there after (I think) the /p
Expand
OK, I'll add that in and see what happens!
It is still ignoring the last folder. The folder structure is Back Door, Back Door 2, Driveway, Front Door
The first 3 Back doors and driveway I can see that the most recent file is from July, however in Front Door I have files from 2-19-22 still. So I am confused as to why it is ignoring that folder.
Even going to the folder directly and modifying the command to:
ForFiles /p /s "H:\CCTV\video\Front Door" /s /d -30 /c "cmd /c del /q @file"
does not do anything at all.
Edited by jnelsoninjax
Register a new account
Sign in
    • It was a matter of time. Anthropic must've been bleeding a lot of money with it.
    • OBS Studio 31.1.2 by Razvan Serea OBS Studio is software designed for capturing, compositing, encoding, recording, and streaming video content, efficiently. It is the re-write of the widely used Open Broadcaster Software, to allow even more features and multi-platform support. OBS Studio supports multiple sources, including media files, games, web pages, application windows, webcams, your desktop, microphone and more. OBS Studio Features: High performance real time video/audio capturing and mixing, with unlimited scenes you can switch between seamlessly via custom transitions. Live streaming to Twitch, YouTube, Periscope, Mixer, GoodGame, DailyMotion, Hitbox, VK and any other RTMP server Filters for video sources such as image masking, color correction, chroma/color keying, and more. x264, H.264 and AAC for your live streams and video recordings Intel Quick Sync Video (QSV) and NVIDIA NVENC support Intuitive audio mixer with per-source filters such as noise gate, noise suppression, and gain. Take full control with VST plugin support. GPU-based game capture for high performance game streaming Unlimited number of scenes and sources Number of different and customizable transitions for when you switch between scenes Hotkeys for almost any action such as start or stop your stream or recording, push-to-talk, fast mute of any audio source, show or hide any video source, switch between scenes,and much more Live preview of any changes on your scenes and sources using Studio Mode before pushing them to your stream where your viewers will see those changes DirectShow capture device support (webcams, capture cards, etc) Powerful and easy to use configuration options. Add new Sources, duplicate existing ones, and adjust their properties effortlessly. Streamlined Settings panel for quickly configuring your broadcasts and recordings. Switch between different profiles with ease. Light and dark themes available to fit your environment. …and many other features. For free. At all. OBS Studio 31.1.2 hotfix changes: Fixed an issue in OBS Studio 31.1.0 and 31.1.1 causing Multitrack Video to set the Maximum Video Tracks to 10 if the user had set it to "Auto" [dsaedtler] Fixed an issue in OBS Studio 31.1.0 and 31.1.1 causing Browser Source hardware acceleration to fail in the Flatpak version [reitowo/tytan652] Fixed an issue in OBS Studio 31.1.0 and 31.1.1 where progress bars were styled incorrectly [Warchamp7] Fixed an issue in OBS Studio 31.1.0 and 31.1.1 where spacing around scrollbars was incorrect [Warchamp7] Fixed an issue in OBS Studio 31.1.0 and 31.1.1 where Decklink Output did not work [CyBeRoni] Fixed a freeze in OBS Studio 31.1.0 and 31.1.1 on Linux when using PipeWire capture with explicit sync [YaLTeR] Fixed an issue where Video Capture Devices on Linux could unexpectedly stop capturing video [JiangXsong] Fixed an issue with PipeWire capture on Linux where video filters could cause gamma shift [tytan652] This was done by reverting a fix for white-tinted PipeWire captures in 10-bit or 16-bit color formats, so that issue will return for now. Download: OBS Studio 31.1.2 | Portable | ARM64 | ~200.0 MB (Open Source) View: OBS Studio Homepage | Other Operating Systems | Screenshot Get alerted to all of our Software updates on Twitter at @NeowinSoftware
    • Sandboxie Plus 1.16.2 / Classic 5.71.2 by Razvan Serea Run programs in a sandbox to prevent malware from making permanent changes to your PC. Sandboxie allows you to run your browser, or any other program, so that all changes that result from the usage are kept in a sandbox environment, which can then be deleted later. Sandboxie is a sandbox-based isolation software for 32- and 64-bit Windows NT-based operating systems. It is being developed by David Xanatos since it became open source, before that it was developed by Sophos (which acquired it from Invincea, which acquired it earlier from the original author Ronen Tzur). It creates a sandbox-like isolated operating environment in which applications can be run or installed without permanently modifying the local or mapped drive. An isolated virtual environment allows controlled testing of untrusted programs and web surfing. Sandboxie is available in two flavors Plus and Classic. Both have the same core components, this means they have the same level of security and compatibility. What's different is the user interface the Plus build has a modern Qt based UI which supports all new features that have been added since the project went open source. The Classic build has the old no longer developed MFC based UI, hence it lacks support for modern features, these features can however still be used when manually configured in the Sandboxie.ini. Sandboxie Plus 1.16.2 / Classic 5.71.2 changelog: Added added toggleable INI key validation to "Edit ini Section" #4915 (thanks offhub) added toggleable per-key tooltip support #4928 (thanks offhub) added option to use the new Qt Windows 11 style on SandMan #4927 (thanks LumitoLuma) Changed ImBox no longer updates container file timestamps when accessing an encrypted box volume Fixed fixed Windows 11 24H2 build 26100.4770 causes Firefox Portable 140.0.4 / 141.0 to stop responding upon starting it sandboxed #4920 fixed leak of encrypted sandbox key during password change (backported hardened ImBox from MajorPrivacy) CVE-2025-54422 fixed Firefox Nightly sandbox hook errors Removed removed obsolete Bullguard Internet Security template removed obsolete Bsecure CloudCare template removed obsolete CyberPatrol template Download: Sandboxie Plus (64-bit) | 23.6 MB (Open Source) Download: Sandboxie Classic (64-bit) | 3.0 MB Links: Sandboxie Website | GitHub | ARM64 | Screenshot Get alerted to all of our Software updates on Twitter at @NeowinSoftware
    • Indians never sing "I Think Indian" near giraffes.
    • Malwarebytes 5.3.5.204 by Razvan Serea Malwarebytes is a high performance anti-malware application that thoroughly removes even the most advanced malware and spyware. Malwarebytes version 5.xx brings comprehensive protection against today’s threat landscape so that you can finally replace your traditional antivirus. You can finally replace your traditional antivirus, thanks to a innovative and layered approach to prevent malware infections using a healthy combination of proactive and signature-less technologies. While signatures are still effective against threats like potentially unwanted programs, the majority of malware detection events already come from signature-less technologies like Malwarebytes Anti-Exploit and Malwarebytes Anti-Ransomware; that trend will only continue to grow. For many of you, this is something you already know, since over 50% of the users already run Malwarebytes as their sole security software, without any third-party antivirus. What's new in Malwarebytes 5.xx: Unified user experience - For the first time, Malwarebytes now provides a consistent experience across all of our desktop and mobile products courtesy of an all new and reimagined user experience powered by a faster and more responsive UI all managed through an intuitive dashboard. Modern security and privacy integrations - Antivirus and ultra-fast VPN come together seamlessly in one easy-to-use solution. Whether you’re looking for a next-gen VPN to secure your online activity, or harnessing the power of Browser Guard to block ad trackers and scam sites, taking charge of your privacy is simple. Trusted Advisor - Empowers you with real-time insights, easy-to-read protection score and expert guidance that puts you in control over your security and privacy. Malwarebytes 5.3.5.204 changelog: Introduced Deep Scan, a new Advanced Scan type recommended after blocking or removing threats Added new Windows Firewall Control feature preview to the Tools, feel free to try it and provide your feedback Revisited Dashboard layout for free version Minor usability and localization issues Download: Malwarebytes 5.3.5.204 | 397.0 MB (Free, paid upgrade available) Links: Malwarebytes Website | Screenshot Get alerted to all of our Software updates on Twitter at @NeowinSoftware
      ataho31016 earned a badge
      Gladiattore earned a badge
      NeoWeen earned a badge
      165
      107
