MPG123 Problem
Oh blast it! I am trying to convert some MP3 and MIDI files to WAV using this, but it won't let me, even when I typed in the instructions correctly (mpg123 -w (filename.mp3) --wav (filename.wav) ! Is there a better audio converter than this around or is there some configuration I have to do?
https://www.neowin.net/forum/topic/143092-mpg123-problem/
Just found that out thirty minutes ago as I found a blurd on Google about this, but there is one question I have that remains. How do I convert MIDI files to WAV by using Timidity? There appears to be no visible way of doing this, yet it advertises it can do that? The documentation doesn't seem to be present.
https://www.neowin.net/forum/topic/143092-mpg123-problem/#findComment-1758979
Not much use, so I just e-mailed the developer to see if he can spit it out in plain English instead of the useless documentation method which I read over at least twice in detail. Oh now what! Upgrading the ALSA packages in Slackware caused my soundcard to not function properly! I wonder if there is a way in which I can re-initialize this!
https://www.neowin.net/forum/topic/143092-mpg123-problem/#findComment-1759258
  Danrarbc641 said:
-Ow1S outputs to 16 bit stereo wav, the sample rate is determined by the other settings you use.
timidity -h will help you out, it's all in there ;)
Static Void: Check your private messages.
Danrarbc641: And would I use timidity -Ow1s (filename.mid)? If so, then where would the output file be generated to?
https://www.neowin.net/forum/topic/143092-mpg123-problem/#findComment-1759362
The file would be outputted to filename.wav. If you are burning it to a CD, which you probably are, then you must output it in 44100Hz like:
timidity input.mid -Ow1S -s 44100 -o output.wav
By the way, my /usr/share/timidity/timidity.cfg file looks like:
#on my debian: /usr/local/share/timidity/timidity.cfg
dir /usr/share/timidity/eawpatches
source gravis.cfg
source gsdrums.cfg
source gssfx.cfg
source xgmap2.cfg
#dir /home/user/patches/
#mid -> wav: timidity input.mid -Ow1S -s 44100 -o output.wav
when the eaw patchset was added by Portage.
https://www.neowin.net/forum/topic/143092-mpg123-problem/#findComment-1759387
Tried that in command line and I get an error saying "cannot open display" or something like that. Good lord! I think KDE included the wrong kind of TiMidity if you ask me. Says version 0.2i might I add.
https://www.neowin.net/forum/topic/143092-mpg123-problem/#findComment-1762182
The reason that you are getting that error is because it is trying to open up the GUI by defalut. Try using a command line switch like -iT to force it into the console. When you use the -Ow option, you won't here anything coming out of the speakers, just a wav will be created where you specified with the -o option. Below is a list of available interfaces. We've already determined that you don't have the ncurses one (imo the best one). Try different ones. If nothing else works, update Timidity. If you can't find it anywhere, I've already compiled a Pentium III binary for you. Just let me know and I'll tell you how to get it.
Available interfaces (-i option):
-in ncurses interface
-iT vt100 interface
-is slang interface
-im motif interface
-ie Emacs interface (invoked from `M-x timidity')
-ia XAW interface
-ii skin interface
-ig gtk+ interface
-id dumb interface
-ir remote interface
-iA ALSA sequencer interface
https://www.neowin.net/forum/topic/143092-mpg123-problem/#findComment-1762337
All right. I reinstalled TiMidity++ with the following configure options:
--enable-audio=alsa,arts,vorbis
--enable-interface=vt100,ncurses,xaw,gtk
--enable-network
--enable-wrd
However, I still can't get the conversion to work since it did not generate a timidity.cfg file by default and when I copied the config and the eawpatch files to the proper directory, it still says the config is still screwed up. So it's still the same file as I sent ya on MSN a day ago. Would you happen to know how to modify the configure file so the damn thing works, please? After that, it should be a go!
https://www.neowin.net/forum/topic/143092-mpg123-problem/#findComment-1764674
What do you mean "it still says config is still screwed up?" On my installation, I have in /usr/share/timidity:
  • The timidity.cfg file
  • Some file called timidity.el (I don't know what it does.)
  • A dir called eawpatches with the patches inside.
The timidity.cfg contains what I posted above and what you have in yours.
Since you installed it from source, though, all of the newly compiled timidity stuff is probably in /usr/local/share/timidity and that is confusing the program. Especially since you probably have the older version still installed. Try removing the old stuff. If that doesn't work, remove the new stuff and recompile the new stuff with the configure flag "--prefix=/usr" so that your old stuff would be rewritten.
Man this whole thing is turning out to be way more compilcated than it has to be. Something tells me that everything worked fine before you compiled the new version, it's just that you didn't know it was working. I really wish you could post *exact* console outputs to support your problems.
https://www.neowin.net/forum/topic/143092-mpg123-problem/#findComment-1764808
