Problem with wait() system call
I'm writing a very simple program in linux to fork a child process. The only problem is that when I have the parent process call wait(&status), i get an error that says " 'status' declared as reference but not initialized" status is defined as int status; right in main so i'm not sure what the hell I am doing wrong, although I'm sure it's something simple. Can anyone offer some suggestions?
https://www.neowin.net/forum/topic/143493-problem-with-wait-system-call/
11 answers to this question
Thanks for the offer, but i'd rather not give out the code since it's a hw assignment, university's can be extremely anal when it comes to this sort of thing. I tried changing the variable name and i got the same error. I'm using the g++ compiler. I guess i'll just try to compile it on unix to see if i get the same error. I named the .out file fork, maybe that's causing a problem? In any case i'll try it tomorrow and let you know what happens. Thanks for the input.
Hmm, i just tried the code you posted, this is what I got:
nclude <iostream>
using namespace std;
#include <sys/types.h>
#include <unistd.h>
int main(void)
int status;
if (fork() == 0)
return -1;
wait(&status);
return 0;
errors:
fork2.cpp: In function `int main()':
fork2.cpp:14: conflicting types for `wait&status'
fork2.cpp:9: previous declaration as `int status'
fork2.cpp:14: `status' declared as reference but not initialized
  PseudoRandomDragon said:
I couldn't compile the code for you, didn't have all the libraries. Curse you Borland C++...
fork is not supported in windows.
In Windows, you would use CreateProcess to get an equivalent functionality (not completely)
Cygwin is the only library I know of which has fork() implemented for Windows.
