is there a way to export registry key but in an incremental way , many copies ?
Hi
i would to export some registry key with a bat file but in incremental way  (keep many reg files , with a name and a suffix for example export1.reg export2.reg and so on ) ?
I 'm thinking about a bat file ,just because i can use the windows 11 or 10 task manager and run every x hours or every day
i don't want to export the entire registry but only 1 key or 2 ,with all the subkeys and keep all them
I use a free portable backup jubut portable , cool program ,but only for files, and macrium for image
i'm looking for a script / bat , can a script/bat file do it?
I have't found a free program to export them
thanks
@echo off
setlocal enabledelayedexpansion
set /p "numKeys=Enter the number of registry keys to export: "
set /p "backupDir=Enter the backup directory path: "
if not exist "%backupDir%" mkdir "%backupDir%"
set "baseFileName=export"
set "fileExt=.reg"
set "counter=1"
for /l %%i in (1,1,%numKeys%) do (
    set /p "key%%i=Enter the location of registry key #%%i: "
:loop
set "fileName=%baseFileName%!counter!%fileExt%"
set "filePath=%backupDir%\!fileName!"
    reg export "!key%%i!" "!filePath!" /y
set /p "continue=Do you want to export another set of registry keys? (Y/N): "
if /i "!continue!"=="Y" (
    set /a "counter+=1"
    goto loop
  On 21/04/2024 at 08:15, cacoe said:
Expand
hi Cacoe
may i a question ?
let's say i want to backup these keys
HKEY_CURRENT_USER\Software\Mozilla
Expand
to X:\backupregistry
is your script correct ?
I have added HKEY_CURRENT_USER\Software\Mozilla
the backup folder is X:\backupregistry
about the number of registry key to export what does it mean how many backups?
thanks Caoce
@echo off
set /p "backupDir=x:\backupregisry: "
set "fileExt=.reg"
set "counter=1"
    set /p "key%%i=HKEY_CURRENT_USER\Software\Mozilla #%%i: "
:loop
    set /a "counter+=1"
    goto loop
## Export registry key
# Specify registry key
$registryKey = "HKEY_CURRENT_USER\Software\Mozilla"
# Specify the path to save .reg file
$exportPath = "X:\backupregistry\Mozilla.reg"
# Export the registry key
Invoke-Expression -Command "reg export `"$registryKey`" `"$exportPath`""
# Check if the export was successful
if (Test-Path -Path $exportPath) {
    Write-Host "Registry key exported successfully."
} else {
    Write-Host "Failed to export registry key."
Save as <filename>.ps1, run with PowerShell.
  • Thanks 2
} else {
Expand
Hi @binaryzero  @cacoe
if i click on run with powershell it does work ,I have tried even  in power shell ISE and the error translated in English with google translator is
Failed to load file X:\backupregistryJriver\eportaregistryJriver.ps1. Script execution is disabled on your system. For more information,
see about_Execution_Policies at https://go.microsoft.com/fwlink/?LinkID=135170.
    + CategoryInfo : Protection error: (:) [], ParentContainsErrorRecordException
    + FullyQualifiedErrorId : UnauthorizedAccess
here a command
 Get-ExecutionPolicy -List
        Scope ExecutionPolicy
MachinePolicy       Undefined
   UserPolicy       Undefined
      Process       Undefined
  CurrentUser       Undefined
 LocalMachine       Undefined
Expand
so i opened powershell as administrator windows 11 pro , and copied everything it does create it but only 1 registry backup
i would like to create many backups and only 1
could be make maybe with the bat/cmd  files many files (i have no limit)?
thanks
Set-ExecutionPolicy unrestricted
# Import CSV file
$csvData = Import-Csv -Path "X:\backupregistry\regkeys.csv"
# Backup directory
$backupDir = "X:\backupregistry"
# Check the backup directory exists
if (!(Test-Path -Path $backupDir)) {
    New-Item -ItemType Directory -Path $backupDir | Out-Null
# Loop through each registry key in the CSV file
foreach ($row in $csvData) {
    $key = $row.RegistryKey
    # Define the backup file path
    $backupFile = Join-Path -Path $backupDir -ChildPath ("$(($key -replace '\\', '_')).reg")
    Invoke-Expression -Command "reg export `"$key`" `"$backupFile`""
    # Check if the .reg file has been created
    if (Test-Path -Path $backupFile) {
        Write-Output "Backup for $key created successfully at $backupFile"
    else {
        Write-Output "Failed to create backup for $key"
Save as ps1. Create a csv file with the header "RegistryKey", list key paths underneath.
Expand
hi
i have set unrestricted by default
      Process       Undefined
thanks
  On 21/04/2024 at 09:09, drugo said:
hi Cacoe
may i a question ?
thanks Caoce
@echo off
set "fileExt=.reg"
set "counter=1"
:loop
    set /a "counter+=1"
    goto loop
Expand
The number is simply the amount of keys you would like to save, so if you know you want to save 5 keys, enter 5, then you will proceed to get 5 prompts for 5 different key locations, then it will save to 5 different files to the backup location.
All entries under each key will be saved to each file.
Expand
hi Cacoe
but there is something doesn't work , might you please check it?
thanks
@echo off
set /p "numKeys=5"
set /p "backupDir=x:\backupregistry\"
set "fileExt=.reg"
set "counter=1"
    set /p "key%%i=HKEY_CURRENT_USER\Software\Mozilla"
:loop
    set /a "counter+=1"
    goto loop
  On 21/04/2024 at 18:41, drugo said:
hi Cacoe
thanks
@echo off
set /p "numKeys=5"
set "fileExt=.reg"
set "counter=1"
:loop
    set /a "counter+=1"
    goto loop
Expand
I don't see the issue, I tested it, it's a batch file, I ran it, set it to only do 1 key, selected a random key and it saved the contents to a reg file. What is not working?
  On 21/04/2024 at 20:50, Dick Montage said:
Would it not make sense to just learn PowerShell? Literally so useful
Expand
This.
I provided two code samples, with comments; up to them now...
  • Like 2
Expand
hi Cacoe
it does not save any reg files...
i have tried even this key with all the sub keys
    set /p "key%%i=HKEY_CURRENT_USER\Software\J. River"
maybe the problem is this
set "fileExt=.reg"
set "counter=1"
i should set  ?
set "fileExt=backup.reg
thanks pal
# Import CSV file
# Backup directory
    else {
Expand
Save ^ as "BackupRegistryKeys.ps1".
Create a CSV file called "regkeys.csv", save it in X:\Backupregistry, copy and paste the below.
RegistryKey,
HKEY_CURRENT_USER\Software\Mozilla,
HKEY_CURRENT_USER\Software\J. River,
(or use Excel, save as .csv)
Open PowerShell, run the script, .\BackupRegistryKeys.ps1. Tada
When you want to add more registry keys, add them to the csv file. No need to hardcode paths in the script...
  • Thanks 2
Tidy little script that :) -
(+Extra credit for commenting it properly👍
Still surprises me there is no export-item functionality for the registry in PowerShell, you can do everything else - but for exports you still have to call reg.exe
Instead of adding number -01 etc index numbers, you could just use the date, if you did that you could have just a 1 liner, something like this:
reg export "HKEY_CURRENT_USER\Software\Mozilla" "X:\backupregistry\%DATE:/=-%.reg" /y
Depending on your local date format you might need to change the format of the date variable to suit, or add the time variable too if you are doing multiple exports per day.
RegistryKey,
Expand
hi
first i want to thank you so much
but i can't understand why under windows 11 pro 64bit , from the extension menu run with powershell it doesn't work
it's just handy
will the script save me many *.reg files , like backup.reg , backup1.reg , backup2.reg and so on
appreciate it a lot
# Import CSV file
# Backup directory
    # Get the current date and time
    $date = Get-Date -Format "yyyyMMdd_HHmmss"
    $backupFile = Join-Path -Path $backupDir -ChildPath ("$(($key -replace '\\', '_'))-$date.reg")
    else {
Added a line to append the date and time to the end of the filename; you can change the format yourself, https://lazyadmin.nl/powershell/get-date/.
You're going to need to run this in an elevated PowerShell (run as administrator) session if you're backing up HKLM keys.
If you want to create a shortcut, create BackupRegistryKeys.cmd and put "start %SystemRoot%\system32\WindowsPowerShell\v1.0\powershell.exe -Executionpolicy Bypass -Noninteractive -File "X:\backupregistry\BackupRegistryKeys.ps1". Right click, run as administrator.
Edited by binaryzero
Register a new account
Sign in
