MySQL Problem !
See the attached image - In the right-click menu, it should have other options for creating to deleting database's, but it doesn't ?!?
I got Windows Server 2003 Trial, and i've tried "mysql-3.23.58-win" and "mysql-4.0.18-win" and both version come up with the same problem ?!?
Win Server 2003 is has been great so far, just can't get this working :(
Thanks,
Ferret !
https://www.neowin.net/forum/topic/151275-mysql-problem/
5 answers to this question
WinMySQLAdmin isn't the tool you want to be using to do this. The only reason I ever use it is to install the Windows service for MySQL. You should forget about it after that.
What you *do* need is a MySQL client to connect to the server with. The MySQL folks provide this: http://www.mysql.com/products/mysqlcc/index.html or this: http://www.mysql.com/products/administrator/index.html
I would recommend MySQL Adminstrator for your duties, though.
https://www.neowin.net/forum/topic/151275-mysql-problem/#findComment-1882747
    • Both a game adaptation and it's on Amazon I'll set my hopes low
    • You shut your mouth you young fart, that was just a few years ago, lol.
    • Good effort, but unfortunately not very useful in the real world, since it doesn't support UEFI - which is a major drawback. More than that, most PCs these days have Secure Boot enabled by default, so unless you're tech savvy, the average joe is not going to disable Secure Boot - which means automated Windows > Linux migration programs like this will not work. And if you're tech savvy enough to know how to disable Secure Boot, then you're tech savvy enough to just flash a USB drive and install Linux the usual way - after all, the actual installation process is just point-and-click. So I don't see a use case here to be honest, especially considering the lack of UEFI support - especially when you consider that more and more Linux distros are completely dropping BIOS support (eg Fedora dropped it back in 2022). So this program is a bit too late to the party.
    • I agree with open rights group that the age check companies should be regulated but action does need to be taken imo, they may be called irresponsible parents but the fact is that many don't know how to set up blocks. Why should kids suffer because their parents don't know something? I think the UK has always been a bit like this. We don't say healthcare is your responsibility, we tax everyone and make people register with the NHS. We also don't expect everyone to brush their teeth to maintain dental health, we just put fluoride in their water assuming people aren't brushing enough, because some probably aren't or aren't doing it properly. In general, this way of doing things works.
      Falcon.ai earned a badge
      EYEREX earned a badge
      Electronic Person earned a badge
      CyberCeps666 earned a badge
      165
      123
