For a few weeks now I've been losing sync on my DSL modem connection at odd times that seem to indicate some local external interference that occurs on some kind of schedule. I.e., it will suddenly go bad at precise times like 11:00pm to 12:00am, or 1:30am to 2:00am, or 4:00pm to 5:00pm, etc., and then be fine until the next hiccup. I would like to monitor my connection locally to see if I can identify the pattern. Does anyone know of any software that could create this sort of log for me? I'm running XP Pro, SP1, and using XP's PPPOE software and TCP/IP. The modem is a SpeedStream 5360-123. There's nothing going on that I know of in my place that could be doing this, but I'm on the 4th floor of an apartment building, so my cable may be picking up noise between my apartment and the network interface. Any thoughts? Thanks.
https://www.neowin.net/forum/topic/154454-program-to-monitor-dsl-connection/
  • 1 month later...
i think iv been having it all along. it seemed to go down during winter, i use adsl (bt yahoo) and i find its crap - download speeds rarely go beyond 10 kbp/s unless i fragment them. uploads are above the limit thats on my isps site though:) im guna move to nildram hopefully sometime soon.
Your DSL modem should have an internal IP that you can browse to.
All you would need to do is type that address in IE, and click 'logs' and you would be able to see any errors, and when and the cause etc.
look up your modem brand, and go to their website and look at the modem FAQ on the site, and see if it mentions an internal IP.
Good luck,
Brent.
    • Windows 11 receives a handful of new AI features by Taras Buria Microsoft is supercharging its operating system with a handful of new AI-powered features. Those with compatible computers (mostly Copilot+ PCs) can download a new Windows 11 update that introduces new AI experiences. One of the biggest updates is the Settings app, which now features agentic search to understand complaints about your computer. You can click the search box and tell Windows what is wrong. For example, "my mouse cursor is too small." Windows will then process your request and suggest taking action on your behalf. You can also ask for specific changes like, "change my screen resolution to 1920x1080." The Settings agent is now available for users with Snapdragon-powered Copilot+ PCs. It is coming soon to Intel and AMD-based Copilot+ PCs. Click to Do has received several new actions: Practice in Reading Coach helps improve reading skills by giving feedback and offering suggestions on how to improve. Read with Immersive Reader displays text in a distraction-free environment with the ability to adjust text size, spacing, font and background theme, have text read aloud, break words into syllables and highlight parts of speech. The picture dictionary shows images for unfamiliar words. Draft with Copilot in Word turns a portion of text into a full draft. Actions in Microsoft Teams let you click an email to send a message or schedule a meeting. More AI is available in the Photos app. After a couple of months in testing, the Relight feature is now rolling out, allowing users to adjust lights with AI. You can place three light sources or use built-in presets to edit your photos. Like with the Settings app, this feature is currently available to Snapdragon-powered devices only. Paint now has a sticker generator and a new object select tool that uses AI to isolate the object and edit individual elements, even if they are part of one layer. Snipping Tool has received the "Perfect Screenshot" feature to help you select parts of the screen for a proper cropped screenshot, and a new Color Picker to read colors on the screen in different formats (available on all PCs, not only Copilot+ PCs). Finally, the Copilot app now supports Highlights, a new feature that enables Copilot to show you how to perform specific tasks in the current app on the entire desktop. Today's updates are not just about AI and sticker generation. Microsoft is also improving the performance and security of its system with a redesigned blue screen of death and the new Quick Machine Recovery system. You can read more about those changes here. If you want to get all these updates today, download the latest non-security update for Windows 11 version 24H2, which is now available.
    • Well their mistake was choosing Microsoft, the backstabbers
    • Yet my Surface Pro 7+ was running ok with 23H2, only having issues with the laggy-mess that's the new File Explorer...
    • Brave browser blocks Windows feature that takes screenshots of everything you do on your PC by David Uzondu If there's anything Microsoft Build 2024 will be remembered for, it's the introduction of the controversial Windows Recall on its new Copilot+ PCs. Pitched as a "photographic memory" for your computer, this feature works by constantly taking screenshots of your activity to build a detailed and searchable timeline of everything you have ever seen or done. Almost immediately, critics and security researchers labeled the feature a privacy nightmare, pointing out that a single piece of malware could gain access to a user's entire digital life. In response to the backlash, Microsoft promised that users will be able to filter which apps get recorded, but some developers are not waiting around. Just about a month after the feature became generally available for Copilot+ PCs (it is now rolling out to users in Europe), some app developers took matters into their own hands to protect their users. One such company was Signal, which implemented an opt-out feature called "Screen Security" to prevent its chats from being captured. It cleverly uses a Digital Rights Management (DRM) flag to black out the application window during a screenshot attempt, using the same technology that streaming services like Netflix use to prevent people from recording movies. Now, Brave Browser has joined the party, announcing on X that it will block Recall by default with its v1.81 update, which is expected in the coming weeks. While Microsoft stated that Recall would not capture content from private browsing windows, Brave's new update just tells the Windows operating system that all of its browser windows are private. This prevents Recall from snapshotting anything you do in Brave, not just the activity in a designated private tab. In its announcement, the company did give Microsoft some credit for making changes following the initial public outcry, such as making Recall an opt-in feature. However, the company still feels that giving any application unrestricted access to a user's browsing history is a huge risk. If you, for some reason, like Windows Recall, you can disable the upcoming protection by navigating to Settings, then Privacy and Security, and toggling off the "Block Microsoft Recall" option.
    • I have the Tab A9+ also, and I agree with all your points. I really like this tablet.
    • Community Regular
      vZeroG went up a rank
      Community Regular
    • Collaborator
      Snake Doc earned a badge
      Collaborator
      131
      122
