cant right click in start menu in XP
didnt know that that was disabled! thanks...
and another problem, when im pl,aying a gmae or a video it will suddenly studder to basically a standstill, and i have to wait a few seconds for it to kick back in. i figured out that it is vsmon.exe that is taking all of my CPU. anyone know why?
edit: no, its not vsmon.exe, it explorer.exe! wtf..... how do i fix that
  moogoat said:
my system does that too, but it's System Idle Process that takes up all CPU...
thats just how much CPU is free
and i have all of the updates, BUT when i go in WU it says i need to get the same ones i already got three times before.....
If thats the case, try again and again.
If doesnt show up in add/remove and shows it again on WU, might have to delete the catroot2 folder, delete all temp files, etc etc and try agin.
  Rell said:
Well, read his above posts ...
I think you should read his above posts.
He is having trouble installing Windows Updates via the web site.
If he fixes this issue which is easy enough, he can get all the updates and critical fixes.
Reinstalling is a stupid idea.
Rell Posted on Apr 6 2004, 11:38
  DaCoOlNeSs, the issue is with custom themes and reinstalling xp would fix the issue.
And how is it related to custom themes? How is Windows Update not installing related to this? Im using custom themes. Most people on Neowin using custom themes. Please elaborate how his issues are related to custom themes and why he should reinstall windows becuase of these custom themes!!
  DaCoOlNeSs said:
nope, it still happens after deleting everything to do with temporary stuff
what about upgrading to XP Pro and trying?
Delete the contents of this folder.
C:\Program Files\WindowsUpdate\V4
Firstly
Go to Start/Run/CMD and type in:
del /q "%SystemRoot%\System32\Catroot2\Edb.log
Secondly
Rename or delete the catroot2 folder and or do the following
At the command prompt (Start/Run/CMD), type the following commands, pressing ENTER after each line:
net stop cryptsvc
ren %systemroot%\system32\catroot2 oldcatroot2
net start cryptsvc
and
Lastly
Open a Command Prompt and re-register the following files by typing "REGSVR32 <FILENAME>". Don't use the "<>" and substitute the appropriate file. Then press Enter - you should get a "succeeded" message on each attempt.
The files are:
SOFTPUB.DLL
WINTRUST.DLL
INITPKI.DLL
DSSENH.DLL
RSAENH.DLL
CRYPTDLG.DLL
Edited by Davey
Did you reboot before you tried? or at least retsrated the browser? : Yes
Did you rename/delete the catroot2 folder? : wont let me!
Did you remove the contents of the Programs Files/Windows Update folder? : i dont have one.....
Did you delete all temp information? : yup
Will let you.
Can try safe mode, or the following
net stop cryptsvc
net start cryptsvc
Go to my computer, Tools, folder options, View Tab and select 'show hidden files and folder' and click apply and ok.
Its might be hidden in the Program Files folder but should see it now.
Might want to read his past posts on the forums too... :)
well, i tried upgrading to XP Corporate, and it makde things worse.
it crashes more often now
Windows update is doing the same thing
if i HAVE to, i can reformat......but i think that this is where this is leading to, isnt it.
