Need help with forms.
I'm fluent in HTMl although not with this part.
I'm making a custom home page and at the top of the home page is a search box. What I would like to do is have it so there is a text box, drop down box and a search button. (I have all three already.) When you select an item in the drop down box that is where it will search. I have no idea how to implement this. I know how to get it to search one site but not how to get it to search the selected site. :(
https://www.neowin.net/forum/topic/159891-need-help-with-forms/
4 answers to this question
Well the page that it posts it's data too will need to decide what site it searches.
Either via a procedure\function or by If...Then or Select...Case argument.
e.g
if request.form("NameOfTheSelectBox"google.com" then
'do stuff to search google
elseif request.form("NameOfTheSelectBox"dogpile.com" then
'do stuff to search dogpile.com
end if
Or something?
good luck
b :)
I'm trying to get this done in HTML.
Sites I want to search on the fly are: Amazon.com, Google.com, Google.com Imges, Download.com. I might add more if needed. It would be great to learn how now and apply those to future forms. I don't know what terms to search for to find a tutorial or know any sites that have the same. (Drop down for multiple sites) or I would try it myself.
Maybe you can use javascript to change the action of the form or the method if neccessary to reflect that of the chosen search engine. Like google
<html>
<head>
<script type="text/javascript">
function searchengine(){
 ?if (document.form.engine.value == "google"){
 ? ?document.form.method = "get"
 ? ?document.form.action = "http://www.google.com/q"
</script>
</head>
<body>
<form name="form" method="get" action="http://watever.com">rch for: <input type="text" name="query">
<br>Search Engine: <select name="engine" onchange="searchengine()">
<option value="xyz">XYZ</option>
<option value="google">Google</option>
</select>
</form>
</body>
</html>
or something similar.. Try it.. Haven't tested the above code myself eith:p... :p but it should work.
Thanks for telling me to use Javascript. I found this and used it:
http://javascript.internet.com/forms/multi...rch-engine.html
It came with a few more so right now I can search; Google.com; Archive.com; Dictionary.com; Download.com; eBay.com; HowStuffWorks.com; Google Images; Thesaurus.
Now I need to find out how to search Amazon and i'm set. :)
