  GwaRGuITaR said:
i dunno, but i wish he wouldn't have stopped development on this! :(
there are a few alternatives, but still nothing even CLOSE to as good.
does it give you an error message or anything? i know it doesn't like compressed files.
Agreed. Try reinstalling it, or removing any recent software or beta driver you may have installed.
thats the problem .. its not giving me any error messages at all it simply doesnt replace the image .. i thought maybe it was a preview bug so i tried saving and reopening to see if the new image would show but its just not replacing it ..
and i have tried reinstalling it .. i usually have it in my windows folder so i can run it from the run prompt but i reinstalled it in its own folder in program files to see if it would help ..
  JCAP said:
thats very weird :unsure: have you tried Resource Tuner?
thats a great program however there is a free program called PEResourceExplorer that does basicly the same thing. however they both lack the ability to import an image from another dll or exe and that is the one feature that is particularly handy :)
