Neowin System Build Guides
This came from another post on Neowin. Here's the link: https://www.neowin.net/forum/index.php?showtopic=177205
So, since I've never posted a thread quite like this, I think we'll start by setting a buget. This week, we want to build a gaming machine for under $1500. This post will work by posting components. Be sure to include the place where you found the item with its price. At the end of the week, I'll post a poll on the parts and do a review of all the components listed. Each week, i'll start another post.
Rule#1: No flaming or complaining about the posts.
Rule#2: Submit ONLY complete system configurations.
Rule#3: Include the website where you found the part and its price.
Thanks and post soon.
Edited by bigrlittlealex
https://www.neowin.net/forum/topic/177350-neowin-system-build-guides/
To make this simple, I'll limit the posts to only Pentium 4 Components, since they have better performance.
Rule#2: Submit parts or complete systems.
You may may start a flame war saying that Pentium 4 is all thats allowed, but thats just me.
i find that rather limiting too.... but its your choice.. the amds would save your ass if your on a budget.... but hey
grab a 2.4 or 2.8c some ddr400 and an ic7 max 3 mobo..
then look at an amd mobile 2500 some ddr 400 and an nf7-s mobo... get some decent cooling and you can oc nice and far
throw on a ati radeon 9600 xt or i dunno a 9800 pro
which one comes out cheaper my friend... your "guide" is flawed... i suggest you alter it
And then add the prices together, and you'll see a big difference in just the mobo + cpu + ram department.
well considering the mobile 2500 doesnt really need the 3200 you could reduce costs even futher...(but it works well for great oc's) but yeah.. agreed homer
Yeah as some people might simply want to buy the cpu for the reduced heat output and power usage. EG. if electricty costs a lot and your comp is in a small room, thats when a mobile cpu looks nice.
Okay Okay..... My idea was to limit the proc specs to one structure per week and change the structure every week. But I can go both ways. I run AMD processors. Thats why i chose Intel. I figured it would give me a chance to see the other side of the force.
Okay... Posts can use any architecture they want. Sorry to upset everybody
I'll Save you the trouble.
Pentium 4 3.0C
OCZ EL PC 3500 2x512MB
Abit AI7
Maxtor 160gb SATA hdd
Leadtek Geforce FX 5900XT
NEC-2500A 8x DVD-R/RW
Creative SB Audigy 2 ZS
Antec Sonata Case
Antec True430 PSU
Logitech MX-510 Mouse
Logitech Elite USB Keyboard
Creative Inspire 6700 Speakers
Viewsonic 19" Black CRT
That all is damn close to 1500 bucks :p I'll conjure up my Athlon XP and Athlon 64 offerings soon seeing as I normally reserve them for dream systems :p (The A64s that is)
Edited by Ecander
I guess this idea really blew the big one. I'll try to think of a better way to implement it. Then maybe i'll try again.
I didn't intend to start a flame war over which proc is the best. At least Ecander got the right idea and posted something. That's the only way this kind of thing works. I hope Aldo has better luck than i did. Maybe i'll try again later.
i would have prefered scenario based .. i mean if you gave most of us a scenario you could include such things as.. the user wishes to only use intel.. you ciuld add graphics contraints etc
how about something like that
I tried that and started a flame war over what was better AMD or Intel. So I changed the post to include all systems.
Sorry, but I have to be somewhat in tune with what people want. I wanted to make restrictions but that didn't fly with the users.
Price Type Brand Model Website
$79.00 Case Artec GUA-BP Guardian zipzoomfly.com
$90.00 Power Supply Antec TruePower True480 zipzoomfly.com
$28.00 Heatsink Thermaltake A1838 Venus Silent Boost K8 zipzoomfly.com
$172.00 CPU AMD Athlon 64 2800+ zipzoomfly.com
$139.00 Motherboard MSI K8N Neo Platinum zipzoomfly.com
$123.00 RAM Corsair CMX512-3200 512MB zipzoomfly.com
$447.00 Video Card Aopen Aeolus 6800 Ultra maincomp.com
$79.00 DVD/CD Writer Nu Tech DDW-082 zipzoomfly.com
$168.00 Monitor CTX VL951T 19? zipzoomfly.com
$74.00 Hard Drive Western Digital WD800JD 80GB SATA zipzoomfly.com
$14.50 Floppy Teac 1.44MB zipzoomfly.com
$90.50 OS Microsoft Windows XP Home zipzoomfly.com
$37.00 Keyboard/Mouse Microsoft Multimedia Keybd & Intellimouse optical combo zipzoomfly.com
$1,541.00 Total
Hope i didn't forget anything. (I just noticed I didn't include speakers) It went a lil over $1,500. (the format looked a lot nicer when I did it on excel) All prices in US Currency as of 2004-06-14
    • It's a Developer Beta 1 not even a Public or User Beta, I doubt any of the design is 100% finalized yet.
    • Was going to comment the same thing. It's SO annoying to have to go back to settings every time I install something new or some apps like discord update and the icon is hidden again.
    • XRECODE3 1.167 by Razvan Serea xrecode3 is a converter and audio-grabber which allows you to convert from mp3, mp2, wma, aiff, amr, ogg, flac, ape, cue, ac3, wv, mpc, mid, cue ,tta, tak, wav, wav(rf64), dts, m4a, m4b, mp4, ra, rm, aac, avi, mpg, vob, mkv, mka, flv, swf, mov, ofr, wmv, divx, m4v, spx, 3gp, 3g2, m2v, m4v, ts, m2ts, adts, shn, tak, xm, mod, s3m, it, mtm, umx, mlp to m4a, alac, ape, flac, mp3, mp4 (using NeroAAC), ogg, raw, wav, wav(rf64), wma, WavPack, mpc, mp2, Speex, ofr, ac3, aiff, tak, snd and Shorten formats. Command Line parameters are supported. XRECODE3 features: Works on XP, Vista, Windows 7, Windows 8, 10 32/64 bit versions and under Wine. Parallel conversion by utilizing power of multi-core CPUs. Support of embedded CUE sheets (for FLAC, WavPack, APE and TAK files). Support of mp4, mka chapters (can split mp4, mka by chapters to any supported format). Built-in Metadata editor with Cover Art support. Has support for LossyWav. Supports portable mode. Merge input files to one large audio file and create CUE sheet. Converting to many formats at once using "Multiple" output mode. Grabbing of multi-channel Audio CDs to the desired format at once. Informative and resizable UI suited even for netbooks. Extracting audio from flv, avi, mov etc. video files (multiple audio streams are supported). Can export/import Metadata to/from external file. Support for 24/32bit audio files. Multilanguage support. Currently program is available in Dutch, English, French, Japanese, Korean, Polish, Russian, Hungarian, Italian, Spanish, Spanish Traditional, Swedish, Brazilian Portuguese, German, Finnish, Bulgarian, Czech, Danish and Chinese (simplified) languages. What's new in XRECODE3: Native 64bit support. Added support for DSD/DST and DFF formats (including handling of SACD ISOs). Added option to extract audio without transcoding. Added option to encode several files to one multi-channel file. Added option to split file into individual track-per-channel for all available output formats. Added option to merge files per folder. Output and Metadata settings are now output format specific. Enhanced Metadata settings. Added support for multiple Cover pictures in Metadata editor. Added 32bit int/float output for formats which support them (e.g. WAV). Added dithering option in Output Settings. Added option to use EBUR128 in Normalize. Added option to Album Mode Normalize. Added option to configure Matrices under Output Settings. Added more output file pattern elements. Tabbed UI. CUE files are now displayed more nicely. Enhanced Shell Extension. XRECODE3 1.167 changelog: Added option to handle YEAR and DATE tags (under Settings/Metadata/Advanced). Updated to the latest qaac (2.85). Download: XRECODE3 v1.167 (64-bit) | Portable | ~30.0 MB (Shareware) Download: XRECODE3 v1.167 (32-bit) | Portable Link: XRECODE3 Homepage | XRECODE3 Screenshot Get alerted to all of our Software updates on Twitter at @NeowinSoftware
    • Hasleo Disk Clone 5.2.2.1 by Razvan Serea Hasleo Disk Clone is a free and all-in-one disk cloning software for Windows 11/10/8/7/Vista and Windows Server that can help you migrate Windows OS to another disk, clone one disk to another disk or clone one partition to another location quickly and efficiently. Completely Free Windows Migration and Disk/Partition Cloning Software Migrate Windows from one disk to another without reinstalling Windows, apps. Clone one disk to another and makes the data on 2 disks are exactly the same. Clone a partition to another location without losing any data. Easily adjust the size and location of the destination partition. Convert MBR to GPT or convert GPT to MBR by cloning. Creation of Windows PE emergency disk. Extremely fast cloning speed and multi-language support. Supported OS: Windows Vista/Server 2008 or later, fully compatible with GPT and UEFI. Note: Hasleo Disk Clone 5.2.2.1 changelog is not yet available. Download: Hasleo Disk Clone 5.2.2.1 | 28.8 MB (Freeware) Link: Hasleo Disk Clone Home Page | Screenshot Get alerted to all of our Software updates on Twitter at @NeowinSoftware
    • Shouldn't using "High Performance" mode prevent c-states from initializing? Maybe AMD hasn't built a proper power plan for their x3d processors like they used to for their ryzen chips.
      viraltui earned a badge
      serfegyed earned a badge
      firey earned a badge
      fettermanj earned a badge
      149
