How to Guide: Change "Run" and other shell32 icons
Recently Browsing 0 members
Posts
By Copernic · Posted
Mass Image Compressor 4.0.2 by Razvan Serea Mass Image Compressor is a fast and easy-to-use Windows app that helps you compress, resize, and convert large sets of images quickly. The tool supports various formats including JPEG, PNG, WebP, AVIF, and GIF (including animated images), and offers precise control over output quality, image dimensions, and file naming schemes. You can reduce file sizes while keeping good quality, change image dimensions, and rename files in batches. Users can filter or preserve metadata such as EXIF, IPTC, and XMP—including selectively removing GPS or serial number information. With features like drag-and-drop, Explorer integration, multiple output folder options, and lossless optimization tools like OxiPNG and pngquant, Mass Image Compressor is ideal for photographers, designers, and developers. Features Compress multiple folders and files in one go (including optional subfolders) Seamless Windows Explorer integration via the "Send To" menu Advanced metadata copy settings (EXIF, XMP, IPTC) with filtering (e.g., strip GPS, serial numbers) Full support for Animated Images (GIF, PNG, WebP) Output to modern formats like WebP and AVIF Regex filters for filenames and size-based exclusions Suffix/Prefix options and filename text replacement for output files Powerful Preview UI with pixel-level image comparison (CTRL + T) Robust and faster RAW image support Multiple flexible output destination modes: Replace original files Output to specific folder Store next to original with suffix/prefix Inside a Compressed subfolder Flexible resizing: By percentage Long edge, fixed width/height Frame-based for print or responsive image sets (1x/2x/3x) Mass Image Compressor 4.0.2 release notes: Major Release: 4.x Series Rewritten from the ground up Complete rewrite using a modern architecture for improved scalability, performance, and responsive UI. Expanded format support: Input: JPG, PNG, WebP, TIFF, GIF, BMP, AVIF, HEIC, JP2, RAW (ARW, DNG, NEF, CR2, CR3, CRW, DCR, KDC, MRW, ORF, RAF, PEF, RW2, SRW, ERF, 3FR, MOS, MEF). Output: JPG, PNG, WebP, AVIF, GIF. New features: Animated image handling (e.g., animated WebP and GIF) Side-by-side preview for compression comparison File filters by extension, size, and visibility Multi-file drag and drop Gallery view modes for better browsing Rich compression settings (quality, resizing strategies, naming rules) Flexible output management (replace originals, custom folders, or preserve structure) Smart conflict handling with detailed warnings Throttled task scheduling for smoother UI Improved metadata support with options to preserve or exclude (e.g., GPS, camera info) Dependency Updates & Stability Magick.NET-Q8-OpenMP-x64 updated from 14.5.0 to 14.7.0 (resolves hang and security issues) Microsoft App SDK updated from 1.6.250108002 to 1.7.250606001 (stability improvements) Download: Mass Image Compressor 4.0.2 | 81.9 MB (Open Source) Download: Mass Image Compressor Portable | 114.0 MB View: Mass Image Compressor Home Page | Github | Screenshot Get alerted to all of our Software updates on Twitter at @NeowinSoftware -
By Thiefyo · Posted
Oh man i didint know why i cannot sleep well ... -
By Mindovermaster · Posted
I wasn't mad. Sorry if I made it sound like that. Everyone is different. PERIOD. -
By Good Bot, Bad Bot · Posted
Of course there are distros that are more beginner (an actual word) friendly and have less setup/configuration out of the box. This is really your argument? There is no reason to be mad because someone said they wouldn't recommend your favorite distro to a certain type of user. Are you committed to revenge now even if it takes a lifetime or something? LOL As a community we really need to move past this. New Linux users need to be helped. In the Linux subreddits the advise is even worse. So many come asking what distro to use. Sometimes they don't mention what they use their computer for and there will be 20 comments of not one person asking that and just listing the distro they personally use. That helps no one. One pet peeve of mine is sometimes one will ask what DE they should use for distro and mention they have been using Windows for 30 years. GNOME is not the damn answer! That doesn't mean GNOME is not a good DE. Understand what I am saying? -
By +primortal · Posted
A lot of throwback names listed there 😀
Recent Achievements
Schwarzenbach earned a badge
NullReference earned a badge
Collaborator
John Volks earned a badge
KenKay earned a badge
Popular Contributors
Tell a friend
