mount: /dev/fd0 is not a valid block device
  Zerosleep said:
That will solve my problem?
/dev/fd0         /mnt/floppy      iso9660     noauto,owner,ro,kenji  0   0
I put supermount right after noauto?
LOL! That's so wrong :| I suggest you read about mount and google supermount.
  Zerosleep said:
Well, I'd like to put auto, but it doesn't matter right now because i can't even do a mkfs, i still get a "bas blocks count" problem.
Did you try to see if mtools worked?
Also, if you are unsure if the physical drive may be bad - or if it is the configuration, try boting with Knoppix (which I know will work with the floppy) to make sure the drive does work.
