  ЀṾ ?? ???g?燎 said:
when u extract the files from the zip/rar of batchmod, u will have a folder 'js'. and a few files in it.
did u by any chance delete the folder or the files in it?
No, I didn't do anything like that and I have no antivirus or script blockers running.
https://www.neowin.net/forum/topic/204873-batchmod-help/#findComment-584377583
    • TotalCommander can use Everything as its search engine, Files should be able too.
    • App size is 441.1 MB, larger and larger with each release. Using doomed and bloated WinUI for foundation was a mistake.
    • Sound Booster 1.12 Build 544 by Razvan Serea Increase volume on your laptop. Boost the volume of even very quiet speakers. Raise volume above maximum. Letasoft Sound Booster can be used as an extra amplifier when the volume of the program you are listening to is too low for comfortable listening and you feel that your PC’s speakers can produce a louder sound. This can be the case when the audio or video has been recorded at the level below normal. Or, for example, when the other person’s microphone you are talking to on Skype, is not working properly. There can be a plenty of other reasons why the sound is being too quiet and there is not much you can do about it except buy external speakers. Sound of any application that is being played in the system can be amplified up to 500%. Letasoft Sound Booster can raise volume of programs like web browsers, on-line communication software (Teams, Discord, Zoom), any kind of media player or games. Simply put, volume of virtually any program that can play any sound in PC, can be boosted to a comfortable level with Letasoft Sound Booster. You can control current volume with the pop-up slider from the system tray. Alternatively, you can assign system-wide hot keys for increasing and decreasing, and use them when you need to adjust volume Letasoft Sound Booster constantly monitors current gain level and prevents samples from clipping, thus reducing all major sound distortions. Download: Letasoft Sound Booster 1.12.0.544 | 7.3 MB (14-Day Free Trial) View: Letasoft Website | Screenshot Get alerted to all of our Software updates on Twitter at @NeowinSoftware
    • how about a very lite version that only have column view. one view that windows explorer does not have.
      Ainajohn earned a badge
      pirateshiptours earned a badge
      Zojaji earned a badge
      151
      116
      wakjak
      113
