Help with FTP in PHP
I tried to write a PHP script for my jobs ftp but I keep getting this error.
Connecting to 64.118.238.214 via FTP
Connected...
Warning: ftp_nlist(): php_connect_nonb() failed: No route to host (113) in /home/alien0us/public_html/static/ftp_ez.php on line 38
Warning: Invalid argument supplied for foreach() in /home/alien0us/public_html/static/ftp_ez.php on line.
here is the source below:
<?php
// ftp script for default user
// fiberlinked@linux.net for questions/comments/death threats
// begin ->
// some variables
$host = "hostsIP";
$un = "def_username";
$pw = "def_password";
echo "Connecting to " . $host . " via FTP";
// connection code block
$ftp_conn = ftp_connect($host) or die("Could not connect to FTP server");
$ftp_login = ftp_login($ftp_conn, $un, $pw) or die("Unable to login");
// end connection code block
// enable passive mode
$mode = ftp_pasv($ftp_conn, TRUE);
// end enable passive mode
// check login & connection
if((!$ftp_conn) || (!$ftp_login) || (!$mode)) {
echo "FTP connection failed.";
else {
echo "Connected...";
// end login & connection check
// run nlist to list directory contents
$dir_list = ftp_nlist($ftp_conn, "");
foreach ($dir_list as $list) {
echo "$list";
//close
ftp_close($ftp_conn);
// end <-
any help?
Edited by fiberLinked
https://www.neowin.net/forum/topic/215975-help-with-ftp-in-php/
2 answers to this question
Check the comments at the bottom of http://php.net/ftp_nlist
There are several people who reported problems with the function. Maybe you should try ftp_rawlist() instead. Someone posted code that converts the output of rawlist to nlist, so it shouldn't be too hard to implement into your existing script.
      Gladiattore earned a badge
      NeoWeen earned a badge
      Doreen768 earned a badge
      165
      107
