jedimasterk Posted October 15, 2004 Share Posted October 15, 2004 How can I fix this. Does the samething in both IE and Firefox. No images showing up. Link to comment https://www.neowin.net/forum/topic/230897-webpage-problems/ Share on other sites More sharing options...
jedimasterk Posted October 15, 2004 Author Share Posted October 15, 2004 Here is another image of MSN hotmail. Link to comment https://www.neowin.net/forum/topic/230897-webpage-problems/#findComment-584739671 Share on other sites More sharing options...
Colin-uk Veteran Posted October 15, 2004 Veteran Share Posted October 15, 2004 maybe its just a problem with the microsoft server? Link to comment https://www.neowin.net/forum/topic/230897-webpage-problems/#findComment-584739680 Share on other sites More sharing options...
jedimasterk Posted October 15, 2004 Author Share Posted October 15, 2004 I tried the website on a computer at work and it was ok Link to comment https://www.neowin.net/forum/topic/230897-webpage-problems/#findComment-584739717 Share on other sites More sharing options...
insanekiwi Posted October 15, 2004 Share Posted October 15, 2004 might be a serverproblem indeed. did you check web features -> load images (under firefox) ? Link to comment https://www.neowin.net/forum/topic/230897-webpage-problems/#findComment-584739734 Share on other sites More sharing options...
lnmnky Posted October 15, 2004 Share Posted October 15, 2004 have you installed anything like Kazzalite? check your hosts file for ad blockers. Link to comment https://www.neowin.net/forum/topic/230897-webpage-problems/#findComment-584739735 Share on other sites More sharing options...
+primortal Subscriber² Posted October 15, 2004 Subscriber² Share Posted October 15, 2004 looks like you got something blocking ads Link to comment https://www.neowin.net/forum/topic/230897-webpage-problems/#findComment-584739742 Share on other sites More sharing options...
jedimasterk Posted October 15, 2004 Author Share Posted October 15, 2004 Tried turning off Antivirus, Firewall, and Adaware, and Spybot. No help. Link to comment https://www.neowin.net/forum/topic/230897-webpage-problems/#findComment-584739755 Share on other sites More sharing options...
lnmnky Posted October 15, 2004 Share Posted October 15, 2004 did you check your hosts? Right click on the ad placeholder, goto properites, copy and paste the address in to a reply. Link to comment https://www.neowin.net/forum/topic/230897-webpage-problems/#findComment-584739782 Share on other sites More sharing options...
jedimasterk Posted October 15, 2004 Author Share Posted October 15, 2004 "res://C:\WINDOWS\system32\shdoclc.dll/dnserror.htm#http://view.atdmt.com/AVE" Got this when I right clicked under bottom add, under URL Link to comment https://www.neowin.net/forum/topic/230897-webpage-problems/#findComment-584739831 Share on other sites More sharing options...
lnmnky Posted October 15, 2004 Share Posted October 15, 2004 So did you check your hosts file....? go here if you don't know.... c windows system32 drivers etc open the host file in notepad. Link to comment https://www.neowin.net/forum/topic/230897-webpage-problems/#findComment-584739975 Share on other sites More sharing options...
zeebaf Posted October 15, 2004 Share Posted October 15, 2004 somehow you are blocking javescript, it maybe with zonealarm. any other firewall. Link to comment https://www.neowin.net/forum/topic/230897-webpage-problems/#findComment-584740007 Share on other sites More sharing options...
Colin-uk Veteran Posted October 15, 2004 Veteran Share Posted October 15, 2004 jedimasterk said: "res://C:\WINDOWS\system32\shdoclc.dll/dnserror.htm#http://view.atdmt.com/AVE"Got this when I right clicked under bottom add, under URL 584739831[/snapback] That sounds like adware.. download Ad-aware and do a scan... Link to comment https://www.neowin.net/forum/topic/230897-webpage-problems/#findComment-584740009 Share on other sites More sharing options...
jedimasterk Posted October 15, 2004 Author Share Posted October 15, 2004 I did what you said and checked for hosts. Their are entries, but how do I correct this problem?. lunamonkey said: did you check your hosts?Right click on the ad placeholder, goto properites, copy and paste the address in to a reply. 584739782[/snapback] Link to comment https://www.neowin.net/forum/topic/230897-webpage-problems/#findComment-584742588 Share on other sites More sharing options...
jedimasterk Posted October 16, 2004 Author Share Posted October 16, 2004 Solved the problem!!. Renamed that "host" file "old host" now everything is ok!!. :D lunamonkey said: So did you check your hosts file....?go here if you don't know.... c windows system32 drivers etc open the host file in notepad. 584739975[/snapback] Link to comment https://www.neowin.net/forum/topic/230897-webpage-problems/#findComment-584744103 Share on other sites More sharing options...
jedimasterk Posted October 16, 2004 Author Share Posted October 16, 2004 Now what would happen if I went back and renamed the "old hosts" file to "hosts" again. Their are so many entries it is hard to find the culprit. Link to comment https://www.neowin.net/forum/topic/230897-webpage-problems/#findComment-584744170 Share on other sites More sharing options...
radagastthethird Posted December 2, 2004 Share Posted December 2, 2004 jedimasterk said: Now what would happen if I went back and renamed the "old hosts" file to "hosts" again. Their are so many entries it is hard to find the culprit. 584744170[/snapback] please help me i have i similar problem but can't fix it, res://C:\WINDOWS\system32\shdoclc.dll/dnserror.htm#http://view.atdmt.com/NL1 what can i do to fix it , went already to folder system 32 but don't know what to do :wacko: bart, radagast@xs4all.nl Link to comment https://www.neowin.net/forum/topic/230897-webpage-problems/#findComment-585029375 Share on other sites More sharing options...
islanq Posted December 3, 2004 Share Posted December 3, 2004 For Fire Fox try going to Tools --> Options --> Privacy, then go ahead and hit "clear" on each thing EXCEPT for your stored passwords. Try reloading the page, probably a broswer cache issue. For Internet Exploere go to Start Menu --> Control Panel --> Internet Options, Then click "Delete Cookies, Delete Files... also check "delete all offline content" --> and then click Clear History. Then try reloading the page. If this doesn't work it's something on Microsofts end of things. Link to comment https://www.neowin.net/forum/topic/230897-webpage-problems/#findComment-585033108 Share on other sites More sharing options...
