Removing stupid right click context menu
My video card installed three items in the context menu:
Save as scheme...
Graphics options
Display modes
It is so irritating because those three items are useless and make the right click menu take a second to load when I right click. How can I remove it?
  PseudoRandomDragon said:
It is disabled. Having it loaded or not in the tray makes no difference. It is an Intel Extreme Graphics card (integrated).
585068741[/snapback]
You must still have it installed somehow. Try uninstalling it in the control panel, restart and check to see if it is running by hitting the windows button and R, then typing msconfig and pressing enter. Take a look at the startup tab and make sure if it is there, it isn't ticked.
[NOTE: There could be more than one instance of it, check your process']
thats the result of "intel application accelerator".....lol...
You need to go to the same website you got that disaster from www.intel.com, and look through the troubleshooting / support section...they have a reg file to download, that removes the right click menu that youve shown in your screenie..
get rid of that intel application accelerator, your graphics card dont need it, as its nothing to do with the graphics drivers..
if you have a look inside C:\windows\prefetch....youll also notice that its disabled "prefetch" applications..
you dont need to uninstall it to get rid of the right click menu, just grab the reg file from intel
