Minimizing Media Player To System Tray?
I use the minimize trick for Outlook where you add the "mintotray" registry value so it does not take up space in your task bar. Can this be done with Media Player as well? I searched the forums and google but came up empty. I cannot download or use any 3rd party software because this is my work machine. I am hoping for another regkey like the one for Outlook. Any help would be greatly appriciated.
Autopatcher XP August edition has something called "WMP Tray" that minimises WMP to tray..You can practically run WMP from the tray with this little gem!!
Its one of those old Powertoys for XP
Got a screenie!! :cool:
Just change the extension to ".exe" from the .txt extension it has at the moment..
Neowin wont let me upload it in its original form...GAY!!
Right-click\save target as
WMP_Tray.txtFetching info...
Edited by Harsh!
Sorry if I was somewhat unclear in the original post. Yup, I was talking about minimizing WMP 9 to the systray. I wish I could use that auto patcher prog, but I just can't download any software. I work in IT for a law firm that is involved in a lot intellectual property litigation and they are very strict about accepting EULA's. We represend HP, among others. Also if there are any hidden back doors or trojans in anything I install, I would be fired no questions asked. I was hoping for something as simple as a regkey. Thanks for the quick responses.
http://homepages.slingshot.co.nz/~xtc_jade...html/Snap12.jpg
585079958[/snapback]
nice app, thank you
  • 2 weeks later...
very nice. thanks.
You can use PCMag's traymin to minimize anything to the system tray.
It used to be free, but awhile back, they decided to be annoying and make people pay for their utilities. That being said... the link to the file on their site still works for some odd reason: ftp://ftp.pcmag.com/archives/2000/0118/traymin.zip
There's tiny, free program called RBTray that I've been using for a while. It allows you to minimize anything to the system tray by right-clicking the minimize button, or through the context menu on the taskbar entry.
http://rbtray.narod.ru/
I've found the program to be indispensible in my day to day activities. :laugh:
Enjoy.
Enjoy.
585165390[/snapback]
welcome to neowin, and i'll check it out... does it run in the background?
