- Click refresh
- Refresh the page
- Refresh the page
- Refresh the page
red.
i have to do a project for univeristy involving sql and forms. when i try to create a data block for certain tables using the wizard in the forms builder i always get an error message saying:
'FRM-10095: Assertion failed in iewbdbc_oracle_to_id, at C:\....'
This only happens with certain tables and it worls with other tables that belong in the same database. Can anyone help me to fix this? thanks.
edit: ok thanks for the help it works now. as you guessed i was using timestamp so i changed it to date.
Edited by redwhornsLink to comment
https://www.neowin.net/forum/topic/262777-oracle-forms-builder-help/Share on other sites
2 answers to this question
