hub vs. router - 3com Superstack II DS Hub 500
I just obtained a 24-port 3com superstack ii dual speed hub 500, but I'm having trouble getting it connected.
I've always used routers for my networking. What's the difference connectivity-wise with this device?
I already tried configuring my IP address manually, and I can ping myself, but nobody else.
If I tell it to obtain the IP automatically, it says I have "limited or no connectivity", I would imagine because the hub does not function as a DHCP server.
What am I doing wrong and what can I do to get them to connect?
I have same router. My last Linksys had an uplink port. But this one doesn't. I used a hub for while on mine. I ran from regular port to regular port, but for the life of me can't remember if I assigned IP or not. I think I did. Wish I could be of more help.
K, I'm going to assume that the 3com is a hub/switch and that the other device is a router. There is a huge difference between these devices. In ye olde days, hubs put data on ALL the lines. This posed a security risk as it allowed you to "spy" on computers sharing your hub. Switches came along and solved this by only sending data down channels that they know a device is on. A router is an entirerly different beast capable of moving data between different subnets. I highly doubt the 3com device you have is a router. This means it wont do the nifty tasks your mom and pop linksys/belkin/netgear/etc cable/dsl routers do, which are actually route and then some. More likely it is a switch. I will henceforth call your internet cable/dsl thing "router" and your 3com device "hub".
First, if you're going to connect the router to the hub, you either need to use a crossover cable (if using two ethernet ports) or a patch cable (if you use one uplink and one standard port). Without this you'll never be able to connect the router to the hub. This should allow you to recieve DHCP data from the router.
Assuming you still can't get a DHCP address from the router, try manually setting the ip address on all the pcs. They will, of course, all have to be on the same subnet. Once that's setup see if the computers can ping eachother. If they can't something is very wrong.
  HPMCommander said:
It's a hub, not a router.
I'm going to try to make a crossover cable.
585269002[/snapback]
Yeah a crossover might be what you need between the hub and switch port of the router.
You might be able to test the hub out by plugging a cable into two ports of the hub and see if you get a link light on both. I'm thinking a straight through won't get one while a crossover will.
I just realized thats a manageable switch. Not some old crappy regular hub. :p
http://www.3com.com/products/en_US/detail....&sku=3C16611-US
This may provide you with some info.
Look on page 3 of the manual. The button specifies an uplink. You need to use port 12 or 24.
Edited by randy_tho
What happens when you do:
ipconfig /release
followed by:
ipconfig /renew
on the PCs? Also, do you only have 3 PCs or are you leaving the others out of the diagrams for convenience? If you only have 3, stick with the router only. Using the hub would just slow things down.
    • Editor: "YouTube is bring" should be "YouTube is bringing" in your main article title.
    • Opera files complaint against Microsoft for manipulating customers into using Edge by Usama Jawad Most of us here at Neowin are well aware of Microsoft's tactics to get its customers to use its Edge browser. It only recently stopped injecting massive banner ads for its own browser in Chrome's download portal. However, tired of Redmond's continued efforts to manipulate customers into using Edge rather than other alternatives, Opera has filed a complaint against Microsoft in Brazil. As reported by The Verge, the reason for filing a complaint against Brazil rather than any other country is that it is one of Opera's main markets, where the company enjoys a respectable third place. Opera hopes that Brazil will set a global precedent for other countries if it rules in its favor. Regarding the actual nature of the complaint, Opera alleges that Microsoft leverages "manipulative design tactics" and anti-competitive methods to force people into using Edge. Examples of this include third-party browsers not having the option of being bundled in a Windows installation, and the fact that Microsoft's own tools like Widgets, Teams, Search, and Outlook ignore a user's browser preferences and prioritize Edge when opening file like PDFs. If Brazil's regulator does rule in favor of Opera, the company will be seeking remedies like the ability to pre-install other browsers in Windows by default and restricting "dark patterns" that force customers to use Edge. This isn't Opera's first legal battle with Microsoft in recent memory. A little over a year ago, it pressured the European Union (EU) to label the Redmond tech firm's browser as a gatekeeper under the Digital Markets Act (DMA) due to the dominance of Windows in the desktop space and the inability for users to select a browser through a choice screen. However, Opera was unsuccessful in its efforts. As such, it will be interesting to see if it can score a win against Microsoft with its complaint this time.
    • Apprentice
      MikeK13 went up a rank
      Apprentice
      andeyhawk65 earned a badge
      Jake2530 earned a badge
    • Explorer
      Deranox went up a rank
      Explorer
      John Volks earned a badge
      179
      100
