Connecting Printer to Wireless Network Router
Hi guys. Here's whats happening. I want to be able to print from my laptop to my HP Deskjet 5550. But it's connected through the main computer. So I have to turn on the printer, then turn-on the main computer, then i have to log in. So that I can print.
I want to be able to just straight out print from my laptop. I have a Netgear Wireless Router MR814v2. And a HP Deskjet 5550.
Thanks in Advance,
ninjakarl
Ok, a couple of things.
Does the HP have a ethernet card? As its a deskjet, I doubt it, but many of their laserwriters have built in NIC's. If this is the case, you should just be able to set a fixed IP in the printer, and then plug it strait into the router.
If it doesn't have a nic, you have to get a network print server. At the moment, your desktop is filling this role.
HP printers that have inbuilt nics use a card called a HP Jetdirect. This is HP's version of a ethernet server for the printer. Before they were internal, they were a box that sat next to the printer, connected via ethernet to the router, and via parallel to the printer. External HP Jetdirects are now fairly cheap to pick up if you know where to look. But there are many other Network Printservers out there. Find one that supports your printer, and then you can give it a fixed IP.
Then all you need to do is setup IP printing on your laptop, or print to the name you gave the printserver.
