Drawing problem with list box [.NET]
Ok, this might be hard to understand but anyways:
i'm currently inheriting from the ListBox control and providing my own drawing code.
I'm drawing a gradient background on each listbox item. All fine, however the gradient i'm drawing is a little away from the edge of the actual rectangle so youll see some white space around the actual rectangle.
All fine till when you run it and when u resize the listbox, only the first item gets refreshed and draw appropriately.
If i drew the gradient so that it covered the whole rectangle up with no spaces between the edges, and if i resize it during runtime, all the items become drawn correctly.
Here's a screenshot of the issue when it's resized
http://www.ug.it.usyd.edu.au/~wpan6331/ss/ss.JPG
Has anyone experienced the same situation before?
Thanks
https://www.neowin.net/forum/topic/270286-drawing-problem-with-list-box-net/
13 answers to this question
  dannyres said:
You could try setting the ControlStyles.ResizeRedraw flag.. I'm pretty sure that will fix your problem..
this.SetStyle(ControlStyles.ResizeRedraw, true);
By the way very nice looking listbox you've got there. :)
Dan
585278752[/snapback]
Thanks, i've tried al the SetStyle options.
Doesn't help, try it yourself actually, if u dont mind
draw a gradient inside a listbox item, and make it so that its off the edges of the rectangle and resize and ullsee it happen too.
  dannyres said:
Ah ok, I don't have time to try it myself right now, but you could try filling the bounds with white (Graphics.Chear(Color.White);) then drawing ontop of that.. Hopfully that will solve your problem.. :)
Dan
585281362[/snapback]
lol that doesn't really work, it then causes only one listbox item to be drawn.
Ok update guys, i overrided OnResize, so i have to invoke mybase's resize method, added ResizeRedraw for the styles that fixed it up, now i'm left with a listbox that flickers really badly, has anyoen got any other tips they can share to avoid this flickering, i've used double buffer, doesn't work, it also said to truly enable double buffer u have to set the AllWmPaint one and the UserPaint styles, however UserPaint stuffs up the drawing.
Any other suggestions guys?
Thanks
  dannyres said:
You could try doing the double buffering yourself by creating a temporary Bitmap object which you will draw ontop, then paint that to the screen.. :)
Dan
585284364[/snapback]
I did that in some test code and it didn't help for me, although the SetStyle with DoubleBuffer worked for me.
What kind of paint trouble do you get when you use SetStyle?
585284643[/snapback]
Hmmm i'm gonna have to show you, sometime when you're free and when you're on msn lol
    • As a VR2 owner I don't think any thinking was involved with this product, mines mostly used to watch 2D content on a large screen, if I had a modern graphics card the VR would no longer be attached to the console
    • Can you please elaborate on what you mean by nuking it and the steps to do so?
    • I know, but I'm a creature of habit. It's hard enough for me to use macOS. I've been using Windows since I was 6. I do want to try Linux with the mini PC at some point since I have another desktop to use.  When you say wipe it, I'm assuming you mean to connect my USB drive with Windows to the mini PC, power it on and boot from the USB, delete the existing partition, and install Windows? Since I would never get to the desktop the first time, the odds of my USB drive being infected with malware and viruses are low?
    • I wouldn't use it anyway but I agree a price decrease should be present for nothing provided. I'm ok with my wireless charger from anker - I've NEVER plugged my phone in. Even the car base I (built) is wireless charging while it holds it for me.
    • Just got an S25 Ultra.... only because a family member was on an old S10 lite and needed an upgrade so I gave them my S23 Ultra and just bought my new 25. With this being maybe the only decent upgrade from the 25..it's a no deal for me. Honestly I doubt I'll upgrade again for another 3 years. The main reason I went to the 25 ultra was for Satellite usage but apparently duped with only for emergencies. I'm often times in a location with a clear LOS but there is so many customers (Verizon) that the signal is saturated so bad that I can't even send a text message out. It's kinda BS to this day they know there will be that many customers in those tight areas (football stadiums) but won't bring in a mobile trailer to boost signal capacity.
    • Collaborator
      fernan99 earned a badge
      Collaborator
    • Collaborator
      MikeK13 earned a badge
      Collaborator
      Alexander 001 earned a badge
      Antonio Barboza earned a badge
      138
      127
