Logitech LX500 keyboard and mouse problem
Hi,
I have got a problem with the cordless keyboard and corless optic mouse , it seems key are blocked (for example when i play game and I don't touch anything and my guy still running and moving) and the mouse moves alone, i tried lastest drivers but it s the same.
MSI Neo 2 platinium
AMD 64 3500+@3800+
Corsair XMS extreme PC3200 twinx 2*1024
Sapphire X800 XT PE 570/610
antec 550W true power
Artec Ati silencer 4
Zalman 7000D Al-Cu
3DMark05 6216
what surface do you have your mouse on? because there are some laces on my desk that cause the same problem with my mx 700.
as for the keyboard.. well you might want to check what channel you have it on and make sure you've locked it in (Y)
thank you for reply , in fact I use to put my mouse on a "carpet" and I have tried directely to my desk and it is the same, but on my desk there are lots of spots then I think that I need a really plane surface.
And for the keyboard what do you mean by "channel" ?
Logitech receivers have one channel (CH1) for keyboard and one (CH2) for mouse connections. The connection can be secured between the keyboard and the cordless receiver. For LX50x, I think you should check My Keyboard in SetPoint, find the option for securing your keyboard connection.
But check the quality of reception. It really sounds like some sort of RF interference.
by the channel he means check in the drivers, should give you an option of channel 1 or 2, select say 1, it'll ask you to hit connect on the base station, then on the keyboard and mouse, i had to switch to channel 2 when a cordless phone moved into my computer room
      SekTheFirst earned a badge
      zayanhani earned a badge
      HarryTaylor earned a badge
      Eternal Tech earned a badge
      138
