Ethernet printer connection with router
I have a router with 4 ports for wired connections. If I get this do I connect the printer to a wired port in the router?
Also, will this setup (if that's the way it goes) make it so I can print from my wireless laptop without the wired computer being on?
If it matters, I have a Dlink DI-524.
  bogzolla said:
yes, you plug it in directly into your router
yes, as long as router and printer are on, you can print from wireless laptop.
585410236[/snapback]
What he said :p
Becareful of people getting past your router, it is possible.
you dont need to.
just connect your printer to your computer, (which is on the network, router). and simple SHARE your printer. install all the software drivers on each computer, and it works. thats how i do it in my house. my brother sometime uses my printer :p
Why would he do this when he has a router for this purpose? Basically you are telling him to change to an inferior way of sharing a printer! Doing it your way, you will need to have the computer on that shares the printer, whereas with the router no machine needs to be on, other then the one you wish to print from. What a waste of time.
  lylesback2 said:
you dont need to.
585411201[/snapback]
Please tell us why someone would go out and specifically buy a network ready printer and then not use the network interface? Also he wanted to know if he could print from his laptop when his desktop pc was off.
Did you even bother to read the question?
This wasn't even a debatable question like "What browser should I use?" It was a straight forward question with a straight forward answer.
Yes the printer will work with that router.
Yes the laptop will be able to print to the printer without the pc being on via wireless.
The whole point in getting a printer with a network card is to network it directly to the router/switch so you dont have to use printer sharing.. printer sharing blows..
I got a HP DeskJet 5800 Series and I love the fact its wireless, it was my purpose in getting it (that and it was on sale at john lewis)
But back to the thread
You can just hook it up to the router and configure it using the CD and then create a new Standard TCP/IP port on the laptop for printing
    • That would be nice, if excel could refresh pivot tables without bugs. Frequently you refresh a pivot and all parameters get lost. Now this will happen automatically. Bravo MS!
    • If one could ever put all the crap of the world in one box, that would be Microsoft.
    • The most corrupt and vile CEO any company ever had ! The only company that makes an insane amount of money decade after decade but doesn't deliver on even barely passable quality to customers, screws over partners and treats employees like trash
    • PSA: Some other versions of Windows are losing support on October 14 too by Usama Jawad All of us here at Neowin likely know pretty well by now that Windows 10 is reaching end of support on October 14, 2025. You can extend support through paid and "free" means, but if you don't, you won't get any more security or feature updates following the aforementioned date. We also highlighted that the Long-Term Servicing Channel (LTSC) version Windows 10 22H2 is also reaching end of support on that date. Now, Microsoft has reminded customers that yet another variant of Windows is reaching end of life on October 14, 2025 too. On the Windows Release Health dashboard, Microsoft has published a reminder that the Enterprise, Education, and IoT SKUs of Windows 11, version 22H2 will hit end of support on October 14 as well. It is important to keep in mind that the Home and Pro variants of Windows 11, version 22H2 already reached end of life on October 8, 2024, and the extra year of lease on life will end for other SKUs within a few months too. Windows 11, version 22H2 for IoT, Enterprise, and Education was released on September 20, 2022, which means that they would have received just over three years of support by the time they "die", compared to the regular two years for Home and Pro. Customers on any of these versions should consider upgrading to version 23H2 or 24H2 as soon as possible, which have end of support dates of November 10, 2026 and October 12, 2027, respectively. Staying on a supported version of Windows is crucial as that allows you to receive regular security updates on your machine. If you're an IT admin, you should immediately begin planning a migration to a supported version of the operating system, and if you're an employee or someone using these versions of Windows in some other scenario, go to Settings > System > About and check out Windows Specifications > Version.
      hhgygy earned a badge
      NIKI77 earned a badge
      artistro08 earned a badge
      Balaji Kumar earned a badge
      167
      123
